Need a quick answer: swapping fuses
Old Sep 10, 2008 | 07:59 PM
RPL's Avatar
RPL
Can you replace a 10 fuse with say a 25 fuse?
Old Sep 10, 2008 | 08:36 PM
Dan in St Louis's Avatar
If you don't mind risking your wiring harness.
Old Sep 10, 2008 | 08:41 PM
RPL's Avatar
RPL
Thanks.
Old Sep 10, 2008 | 10:31 PM
Joe_Camel's Avatar
Read my sig, Loverboy knows! And btw, thanks for setting me up with a post that fits my sig perfectly.
Old Sep 10, 2008 | 11:46 PM
GreenGoblin's Avatar
The goblin resurrection
nope that size fuse is in there for a reason
Old Sep 11, 2008 | 08:10 AM
ProfanityPete's Avatar
I actually thought about that quote as soon as I read the thread name..
Old Sep 11, 2008 | 02:17 PM
Tollboothwilley's Avatar
in a temporary bind, you can use a smaller fuse...but i wouldnt ever use a higher fuse
Old Sep 11, 2008 | 02:53 PM
ttrank's Avatar
Grocery getter
I agree. Always go smaller and don't push the load on that system.
What fuse are you talking about?
Old Sep 11, 2008 | 08:49 PM
RPL's Avatar
RPL
^It was my rear taillights. I did the non-lazy thing and went out and bought the smallest box of 10 fuses that I could (~5).
The reason why I asked is because I have all other sizes of fuses hanging around! But it always seems that the 10 ones blow.
Joe - I'm glad I could have been of service
Old Sep 11, 2008 | 09:32 PM
Joe_Camel's Avatar
Maybe you have a short on that circuit if the same one is blowing out repeatedly? Check that **** out, you don't want your G35 to catch on fire.
Old Sep 11, 2008 | 09:45 PM
ttrank's Avatar
Grocery getter
If they blow again there must be a problem somewhere...
Old Sep 12, 2008 | 01:26 AM
RPL's Avatar
RPL
No, the fuse is not being blown repeatedly. However, mostly due to user error, the fuses that do seem to blow as I'm tweaking with my car all seem to be 10. It happened with my DSM as well!
Old Sep 14, 2008 | 11:11 AM
Q45tech's Avatar
Careful there are no standards for replacement bulbs. Oem Japanese bulbs may draw less current than copies from Mexico or China.
Past experience [18 years on Q45] shows the Sylvania long life bulbs may work for a while but oem [usually Toshiba] is better.
Cold bulbs drawn an inrush of high starting current vs operating current.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
