5AT Reliability
Old May 27, 2006 | 12:24 AM
AlcatrazT2's Avatar
5AT Reliability
What’s the general consensus regarding the 5AT transmission?
I’m confident the transmission will do just fine under normal driving conditions but how does it hold up when it comes down to spirited driving?
To all of you that continuously track your cars; what do you have to say?
Thanks in advance.
Old May 27, 2006 | 12:25 AM
GLuXuRy's Avatar
Spirited driving its fine... 350ZNV tracked his Stillen SC stage 2 5AT coupe and he said the tranny held up nicely
Old May 27, 2006 | 12:30 AM
AlcatrazT2's Avatar
Are there any official max. power output numbers available?
If not, ballpark, how much safe horsepower/torque can we run?
Thanks =)
Old May 27, 2006 | 12:51 AM
GLuXuRy's Avatar
safely like 350? most guys with FI and are running around 400hp+ they do upgraded valve body and torque converter.. i have yet to seen a upgraded flex plate
Old May 27, 2006 | 01:19 AM
SmokeG305's Avatar
350 to the wheels or crank?
Old May 27, 2006 | 01:21 AM
GLuXuRy's Avatar
wheels... im no car expert... but thats what i would feel to be a safe HP raiting
Old May 27, 2006 | 02:24 AM
ryoken's Avatar
I've had my 03.5 5AT Sedan since December 02. It's still all stock, but I autocross it once or twice a month, which goes beyond "spirited" driving. (I do that too on the commute to/from work occassionally.) So once or twice a month the car gets pushed hard -- DOT-R tires, literally smoking brake pads, and burning through an 1/8 of a tank of gas in what is effectively less than 10 miles.
The tranny seems to be in as good a shape as the day I drove the car off the lot.
Old May 27, 2006 | 03:45 AM
absolutg's Avatar
workin...
urban has 30k+ miles on his vortech on an AT, 420 hp and no valve body upgrade
Old May 27, 2006 | 11:04 AM
DaveB's Avatar
The 5AT is the same unit used is the Q45, M45, and Titan. I'd have to say it's more than up to the task of handling 300wtq and high loads (towing). Remember not to trust a shop that rates a tranny in HP. It's the torque that kills a tranny, not the HP. Also, HP is derived from torque. These trannies could easily handle 600hp if they were in an F1 car because the motor only makes about 250 ft/lbs of torque. But a 500hp/500ft/lb Viper V10 would turn the tranny into a pretzel.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
