Any pics of upsized tires instead of a drop?
Old Jun 14, 2006 | 08:36 PM
  #46
Machine Head's Avatar
245x40x19 not perfect but there are no proper lowing kits for my X so it'll do for now.
Old Jun 14, 2006 | 08:40 PM
  #47
vrsc's Avatar
Originally Posted by Machine Head
[245x40x19 not perfect but there are no proper lowing kits for my X so it'll do for now.
Car looks good!! 350 Z Suspension would work
Old Jun 30, 2006 | 04:59 PM
  #48
gfolo19's Avatar
is that the nismo front? when you getting the rest on?
Old Jun 30, 2006 | 05:45 PM
  #49
trey.hutcheson's Avatar
Both Cheryl and I are running 245/40/18's. Like another person in the thread, Kumho asx's. I think they ride fine. They communicate very well. But I think they slip too much.
Anyway, the shorter sidewall definitely accentuates the wheel gap on both cars. Cheryl is still at stock height, and I'm dropped on coupe shocks/springs. My wheel gap looks bad, but hers is horrid. In my case, the combination of black tires+black wheels+gap make my 18's look smaller than they actually are. Like someone else mentioned, 245/245/18 is closer to stock than 240/45/18. I think I might go with the 245/45's next time around.
Old Nov 22, 2006 | 01:45 PM
  #50
Jestech's Avatar
That looks really good without a drop. What are the offsets?
I'm in the same boat, with an 06X.
Old Nov 22, 2006 | 06:19 PM
  #51
VQ Hotness's Avatar
Thats just going to give you a thicker sidewall is that your goal ?
Old Nov 22, 2006 | 07:09 PM
  #52
esfoad's Avatar
Here's mine, no drop, with 245/45/18's. These are for sale since I found another set in the same size but a different style. Check in the Marketplace! I think you get the idea how well this size fills the wheel wells on the "X".
Attached Thumbnails Any pics of upsized tires instead of a drop?-driverside.jpg   Any pics of upsized tires instead of a drop?-driverfromfront.jpg
Old Nov 23, 2006 | 01:01 PM
  #53
perry05G35's Avatar
Originally Posted by jimmyc13
I did just that (upsized tires instead of a drop).
My OEM wheels are 17's:
215/55/17 yields 118.25mm sidewall = 4.66 in.
4.66+4.66+17" rim = 26.3 inch O.D. (outer diameter) total
My 19" Axis Milano wheels & tires:
245/40/19 = 98mm sidewall = 3.86 in.
3.86+3.86+19" rim = 26.7 inch O.D. total....car is technically only 0.2 inches (3/16") higher off the ground and the gap is filled by the same amount when compared to OEM size.
Here are some pics...I love the look & won't ever be dropping my car....to me, the gap is even all the way around (sides vs. the top) and I like that look. I can only fit 2 fingers between the fender & the wheel.
Where did you get the infiniti center caps from to fit your milanos?
Old Nov 23, 2006 | 01:09 PM
  #54
perry05G35's Avatar
245/40/19 this was before my springs but I have since put my factory springs back on so it looks the same today.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
Jnm07
Aug 6, 2015 03:03 AM
bjo16
Aug 4, 2015 09:52 AM
Soumilg
Jul 18, 2015 12:33 PM
