Differential Gear Ratio
Old Jun 10, 2006 | 09:53 PM
nelam's Avatar
Hi All,
I came across a thread earlier regarding engine rpm vs. vehicle speed.
I noticed my '06 Sedan with Sport Package revs. @ ~3,200 rpm when cruising at 80mph in top gear, which seems to be higher.
Does a '06 model with VSLD has higher differential gear ratio?
Thanks,
Nelson
Old Jun 11, 2006 | 01:28 AM
ttrank's Avatar
Grocery getter
Not as far as I know.
The AT is ~3.3 and the 6MT is ~3.5
Old Jun 11, 2006 | 06:36 AM
Klubbheads's Avatar
6mts are about 3k and autos are 3.3k when doing 80 mph.
Old Jun 11, 2006 | 08:58 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
It's the other way around... the AT pulls fewer RPM
Old Jun 11, 2006 | 10:04 AM
GEE35FX's Avatar
I agree, from what I have read, the final drive ratios have not changed with year models.
The manual and auto RWD models should be within a couple hundred rpm in final drive.
The Auto RWD is 3.357:1 with a final drive ratio in 5th of .834:1,
whereas;
The 6MT RWD is 3.538:1 with a final drive ratio in 6th gear of .794:1
So the changes in the differential gear ratios is somewhat compensated by the transmissions final gear ratios when in top gear.
The AWD differential ratio is 3.538:1 with the autos 5th gear ratio being .834:1
Old Jun 11, 2006 | 01:54 PM
ttrank's Avatar
Grocery getter
No, the 6MT is lower. My buddy at has a 5AT and he sits at about 3,300 @8-mph and I am at about 2,900 with the 6MT.
Old Jun 11, 2006 | 01:58 PM
Msedanman's Avatar
O.F. Administrator
Yeah Ian, don't forget the 6m/t's have the extra cog.
C.
Marlin84
Apr 1, 2020 12:52 PM
Dannyy06
Sep 25, 2015 11:32 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
