Calling all "X's" with a lowered suspension!
#1996
@apintojr - yeah the backs are kind of annoying because for me I want max comfort but I can't tell if I have too much shock and too lil spring etc...always easy to adjust height because its mainly on the spring I believe... but yeah on the preload on the fronts...you're running 10mm? how's that going? can you describe to me if it made it more floaty or more stock?
#1998
So guys I think I might have found a solution for our knocking. What I did is got some bump stops from a local auto part store and zip tied them to my arm. I did set my arm to all the way neg and before it knocked but this time it has not. I even set them to soft. I am going to drive around more tomorrow and I might lower it some more. If you guys can picture what I am talking about. I will try to take pics tomorrow. I was thinking about getting some with a bolt on the end and drill a small hole in the arms but I think that will be alittle to risky.
i was adjusting the height yesturday, and i didnt have the ***** yet to cut anything like ur video but i did take my friends air hammer and i banged up the spots a little to see if that helped. i didnt go crazy with it though.
i really dont hit that much unless it a nice dip. looking more to just absorb the hitting more then cutting for now.
#1999
#2001
#2003
I would say you will definitely need a kit with S Techs, but may be able to get away without one on H Techs. It's up to you though.
#2004
#2005
& I'm also not very rich. So I need what will be cheapest months down the road.
#2006
#2007
#2008
me & my buddy are in the process of installing the front springs right now. back ones were a breeze. but we are stuck once we got the a-arm off on if we should be taking out the entire bracket connected to the coil/strut/shock or there is another bolt there which seems we could be taking off just the shock itself
#2010
