Calling all "X's" with a lowered suspension!
Rating: Thread Rating: 3 votes, 4.33 average.
Old Feb 22, 2012 | 07:20 PM
  #2221
drifterxG's Avatar
Originally Posted by teflon_don
Im looking at some new 19" Nismo S-Tune wheels for my 2005 G35x. I believe they are selling them for a 350Z, but for $1200 it sounds like a steal. My question is will they fit my X?
here are the specs 19 x 9.0 + 47 front
19 x 10 + 30 rear
I'm pretty sure those will fit. I'm looking to get the same width wheels, but in 20". Just make sure the tire walls match in size. Also look into wheel spacers and rolling fenders if you want a flush look.
Old Feb 22, 2012 | 11:00 PM
  #2222
biller1's Avatar
So i got my BC Coilover's today! They are the second gen with the "progressive" look. Quick question to the guys who have installed them. The rear extenders, do i have to drill a hole or will they go throgh the child seat anchors? Someone said they will go through the child seat anchors and i would much rather go this route than drilling holes in my car. Let me know...
Old Feb 22, 2012 | 11:11 PM
  #2223
FlyingLumpia's Avatar
So guys I was thinking of another way to keep it from banging. I think if you put another bumpstop on top of the other one, that might help. What do you think?
Old Feb 23, 2012 | 01:16 AM
  #2224
2006g35xsilver's Avatar
They will go through the crack between the rear seat and the rear deck. No drilling required. Not sure about through the seat anchors, but that might work as well.
Old Feb 23, 2012 | 10:06 AM
  #2225
biller1's Avatar
Thanks, that's the route i'm gonna take!
Old Feb 25, 2012 | 02:56 AM
  #2226
teflon_don's Avatar
These are the same wheels I was going to buy. After checking out these picks, I changed my mind. Too ricer for me.
Attached Thumbnails Calling all "X's" with a lowered suspension!-nismo-wheels-11-.jpg   Calling all "X's" with a lowered suspension!-nismo-wheels-2-.jpg   Calling all "X's" with a lowered suspension!-nismo-wheels-1-.jpg
Old Feb 25, 2012 | 10:02 AM
  #2227
To ricer. Authentic Nismo wheel and very rare. Rather have those than some of these other wheels floating out there.
Old Feb 28, 2012 | 08:23 PM
  #2228
Cpoups's Avatar
OEM spring length
I have a 2005 X and want the front fender gap to be the same as the rear. I got some sport sedan springs to see what I will end up with. I know everybody says the drop will be a half inch, but I have seen the coupe and 350Z drops and it seems everyone gets different results. I'm not into a big drop, just want the gaps evened out. Anyway I was wondering if anyone has spare OEM springs lying around, that you could post unloaded spring lengths just to compare the differences between models. I think I have seen that X springs are 14 inches and change.
Old Feb 28, 2012 | 11:58 PM
  #2229
Caracicatriz's Avatar
So I've decided to go the BC coilover route. I plan on dropping it within a 1 finger gap. My question is, what else should I get so that these fit perfectly? Camber arms, Tie rods, Toe Bolts? I don't want to kill my tires really fast so I'd perfer some neutral camber. My tires are 245/45/19 on 19x8.5 wheels.
Old Feb 29, 2012 | 12:23 AM
  #2230
Definitely need adjustable front a-arms (the front has no stock camber adjustment ), rear camber and toe bolts. Probably want rear camber arms instead of camber bolts for more rear camber adjustment going that low. When I got my BC Coils I went with SPC/Eibach A-Arms and SPC/Eibach Camber Arms with Toe Bolts. I got Lifetime Alignment from Firestone, went once and they put everything except the front camber to within factory specs. They asked me to adjust my a-arms myself (I'm guessing they didn't know how to adjust the aftermarket if the stock didn't have any adjustment), which I did and took the car back the next week and I was right around 0 for camber all around. They are a little pricey compared to some others but I am very happy with this setup.
Old Mar 2, 2012 | 11:21 AM
  #2231
Kenan24r's Avatar
I have a 2004 g35x and I wanted to change out my shocks and springs. I want to put on a 2006 350z shocks and springs. My understanding is that it should bolt right up. I just want someone to confirm this to be true. Thank you.
Old Mar 2, 2012 | 12:36 PM
  #2232
The Fixer's Avatar
You should read through this thread and search...who cares if it's 150 pages long, its good info. Anyway, the rear springs and shocks from the 350z will bolt right in. You will have to swap the 350z front springs onto your original struts, since the X struts are different from the RWD G35 and 350z. The X struts have a U-shaped bend at the bottom to go around the front drive axles.
Old Mar 2, 2012 | 12:39 PM
  #2233
ccc123pm's Avatar
X
^^^ what he said...
before you make any other blunders:
https://g35driver.com/forums/g35-sed...ful-links.html
Old Mar 2, 2012 | 12:40 PM
  #2234
mcaron's Avatar
There needs to be a sticky for lots of these questions. We need a stick for like " Properly lowering your X" and in it have things like if your lowering on coilovers you need ALL camber arms and toe bolts if you want your car in spec. ETC.
We keep getting the same questions over and over, no offense to anyone i know the 150 pages is alot to read lol
Old Mar 2, 2012 | 01:22 PM
  #2235
Bastone's Avatar
Already working on it... https://g35driver.com/forums/g35-sed...read-idea.html
No one seems interested though.
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
