40 MM offset on sedans
Old Jul 5, 2006 | 09:13 PM
gfolo19's Avatar
I searched and could not find a concrete answer. I know 35 and 38 are recommended for the sedan as offsets for all around applications; but will 40's all around fit/look good?
chico if your out there help please.
Old Jul 5, 2006 | 09:17 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
If its an 8.5" wide wheel you can do 40 with no problems, it will look good.
-GP-
Old Jul 5, 2006 | 10:18 PM
KrazyEd's Avatar
I have 19x8 with a +40 offset and no problems.
Old Jul 6, 2006 | 12:18 AM
az1anbeethoven's Avatar
no problemo!
Old Jul 6, 2006 | 12:20 AM
Klubbheads's Avatar
how wide is the wheel? If its over 8.5 it should be right on the edge of the fender and it will look good.
Old Jul 6, 2006 | 03:36 AM
skeleton_cru's Avatar
Sedan
You need to specify the wheel width, but like the rest said you should be fine.
Old Jul 6, 2006 | 02:37 PM
ttrank's Avatar
Grocery getter
40's will fit fine unless you are going wider than a 9.5" in the rear or 8.5" in the front.
Old Jul 6, 2006 | 07:01 PM
Chico's Avatar
on either 8" to 8.5" the +40 will work with a 245/35 or 245/40 tire all around depending on the size of the wheel (18, 19 or 20). Give us more specifics and we'll help you better so you don't have to worry about it.
Old Jul 7, 2006 | 01:06 AM
Sedan
You can't go wider than 8.5 in the front.
Old Jul 7, 2006 | 01:11 AM
gfolo19's Avatar
19x8.5 with 245/40/19 tire all around, will 40 mm be sufficient?
Old Jul 7, 2006 | 01:47 AM
Sedan
That will be just fine. Not too tucked in and no worries rubbing the fenders.
Old Jul 7, 2006 | 02:20 AM
Chico's Avatar
+1. Go for it.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
reaper76
Aug 5, 2015 10:13 AM
