Sedan mods to increase torque/acceleration
Old Jul 6, 2006 | 11:53 AM
davistld01's Avatar
Is there any easy bolt-on mod that can be done to a sedan to drastically improve the torque/acceleration? Most of the mods I see result in near-redline power increase, but at the expense of low-end torque. I don't run my car all that hard, but would love to make it quicker in the acceleration category.
Old Jul 6, 2006 | 12:09 PM
bwassul's Avatar
A 3.9 read end swap would do the trick.
Old Jul 6, 2006 | 12:11 PM
jimmyc13's Avatar
Yeah....what he said (just kidding)...I have no idea what he said, but sounds like changing gear ratio.
I think (I don't have one & not 100% sure), but I think a lightweight flywheel/pulley would address your concerns..though it's not an easy "bolt on".
Old Jul 6, 2006 | 12:23 PM
bwassul's Avatar
The 3.9 rear end swap changes the main gear in the rear differential so that the rear wheels turn more times per crankshaft revolution than with the stock rear end. This enhances acceleration but lowers top speed.
http://www.350evo.com/catalog/produc...roducts_id/214
Old Jul 6, 2006 | 02:25 PM
ttrank's Avatar
Grocery getter
You want crazy low end torque get a Stillen SC...
Old Jul 6, 2006 | 02:35 PM
trey.hutcheson's Avatar
Or if you want cheap torque, get the MD 5/16" spacer. It's not going to be a huge improvement, but you have to be pretty numb to not notice it at all.
Old Jul 9, 2006 | 12:10 AM
OCG35's Avatar
yep - spacer is my recommendation too for cheap bolt on torque... either 5/16" or 1/2"
but as previously stated if you want a neck jerk reaction Stillen SC is the way to go (at a MUCH greater expense).
Old Jul 9, 2006 | 12:27 AM
doogie's Avatar
some 13" wheels should do the trick.
Old Jul 9, 2006 | 01:12 AM
abcdang's Avatar
mrev2
Old Jul 11, 2006 | 06:23 PM
klg35's Avatar
lighter tire wheel combo.........if you're into the oem look..get the Z track 18 wheels......18.2lbs front and 18.6lbs rear.......lose the spare tire and jack......then go on a diet of your own...j/k......but true if you want quicker acceleration.....
Old Jul 12, 2006 | 12:59 AM
PWStudent's Avatar
a few things you can do on any car (universal):
1) lighter rotating mass....from wheels to pulleys and brake rotors.
2) increasing velocity, mainly intake, but def exhaust - intake side velocity stacks usually work well, but most times are custom add ons
3) removing weight....but as the old rule of thumb dictates.... 100lbs per tenth of second gained.
4) as said above, lighter flywheel setup, or a torque converter/shift kit for autos, works well.
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
sick_sixspeed
Jul 21, 2015 01:59 PM
Tony_Me22
Jul 21, 2015 08:42 AM
Tony_Me22
Jul 17, 2015 06:30 PM
