Calling all G's with 350z front springs and G coupe rear springs
Old Jul 8, 2006 | 08:49 PM
  #46
mikeee2's Avatar
Today I had 4 passengers in the back. 3 adult and 1 child. Probably under 400 lbs. When it went over bump it had a quick bounce and then the rear kinda jump. Is that a sign of the side tire wall rubbing the fender? Felt like the fender hit the side wall and then rebound up.
Old Jul 9, 2006 | 12:56 PM
  #47
Tunerz_Store's Avatar
Unrevised Z springs up front and coupe springs in the rear. Tires 235/45/18.
Old Jul 9, 2006 | 01:45 PM
  #48
mikeee2's Avatar
Does your rear rub the fender since the coupe wheels flush the fender.
Old Jul 9, 2006 | 02:10 PM
  #49
stnwag0n's Avatar
does anyone know if the 350z roadster springs are different from the regular revised springs regarding height? i picked up a complete suspension from a roadster, but i was only planning on using the shocks with my tein s-techs. i've been contemplating using the rear 350z springs and s-techs in the front to get that raked stance, but unsure of the height the roadster springs will give.
Old Jul 9, 2006 | 11:53 PM
  #50
Not with 235/45's. Camber is set around -1.3-1.4 in the rear. With the 245's it rubbed.
Old Jul 10, 2006 | 12:06 AM
  #51
mikeee2's Avatar
I wished mine camber is at your range. Mines are -2.5 and -2.9.
Old Jul 10, 2006 | 12:52 AM
  #52
God Damn... there should be some adjustment in the rear to get it back under -2.
Old Jul 10, 2006 | 01:07 AM
  #53
mikeee2's Avatar
Before the alignment, the car was at -2.6 and -2.5. The left rear toe was way off before the alignment and by correcting the left rear toe, it knocked the left rear camber to -2.9 and the other side became -2.5.
Old Jul 10, 2006 | 01:39 AM
  #54
Are you getting crazy tire wear? What the hell is your camber up front
Old Jul 10, 2006 | 06:48 AM
  #55
mikeee2's Avatar
I think the front is -1.5 and -1.6. So far the tire is ok since I've only driven like 300+ miles.
Old Jul 11, 2006 | 12:19 AM
  #56
mikeee2's Avatar
Originally Posted by RocketG35
I had Z springs in the rear and recently switched to Coupe springs. I noticed a significant change in the drop. With the Z springs, I could barely get one finger in the fender gap. Now with the Coupe springs, I can fit one+ finger in the gap.
I changed it out for the same reasons many others did - to reduce the drop/get more height in the rear/to balance the look so that the front didn't look so much higher. I also wanted to reduce the harshness of the ride by going w/ the softer 04 spring.
I'm running oversized tires in the back (245/40) as they are the Coupe wheels w/ factory tires...thats why the gap is a bit less than most other fitments.
From your signature you have z spring/shocks in front but only coupe springs in rear. So the rear is running your stock shocks?
Do you have pictures of your car?
Old Jul 11, 2006 | 01:21 AM
  #57
RocketG35's Avatar
Why do I bother to DIY???
Yes I'm running my stock Sport shock in the back (wife thought it was too rough for the baby w/ the Unrevised shock).
I don't have a pic after I switched it out, but I'll try to take one this week and will post. I do think that the front is still high because of our bigger fender well in the front...even with the Coupe spring in the back making the back a bit higher, the fender gap in the front still is a lot more than the back. I think to truly make it look even, you'd have to keep the stock spring in the back when using the Z spring in the front.
Old Jul 11, 2006 | 01:29 AM
  #58
mikeee2's Avatar
That might work for your rwd (but with the stock wheels for rwd, I think the rear gap is quite big too). For my X, the fender gap is huge in the rear with the stock springs. I wouldn't go with that setup, maybe at least swap the rear springs with sedan sport springs to bring it down 1/2 inch.
Does your rear get bouncy with z springs/oem shocks? Most of the X owners with rear z springs/oem shocks are getting the bouncy effect over bumps.
Old Jul 11, 2006 | 01:32 AM
  #59
mikeee2's Avatar
Haha...what you think of this combo for the X.
Unrevised z springs in front, sedan sports spring/shock in rear? That will elminate the bouncy, negative camber issue in the rear and will close 1/2 inch of gap. Hmmmmmm...but the car might be weird when it comes to handling with the uneven springs. The z front/coupe rear would be more level.
Old Jul 12, 2006 | 12:46 AM
  #60
RocketG35's Avatar
The unrevised shock/springs are stiff and bouncy. They are definitely "tight" - meaning minimal body roll and pretty decent turn control (although I'm not racing my car).
Here are the pics of my car w/ the full Z suspension (notice how the rear fender almost touches the tire! - but keep in mind I'm running a 245/40 in the back so the tire is larger than spec). Sorry for the bad photos - I couldn't back the car out as I was in a hurry - I'll try to post the same shots or at least a full side shot when i have a chance:
Then here are some pics of my car w/ the Stock Sport shock and Coupe spring + Z front spring/shock (notice how high the back is now):
And if you're interested...here is a close-up of the front Z spring/shock set up (this is what is still on my car) - notice how high the gap is even w/ the Z spring...an X suspension would be even higher:
