260 versus 298 Factory HP
Old Jul 10, 2006 | 12:07 PM
bugsdad's Avatar
Does anyone know what Infiniti did to take the 6 speed sedan from 260 to 298 in 2005? Has anyone tried updating to get that power...ie an 05 ecu or intake etc?
Let me know if you guys have heard anything on this.
I also have an enthusiast at one of our local dealers trying to find out what created the increased power.
Old Jul 10, 2006 | 12:09 PM
2FastG354U's Avatar
I was always curious how they did that to the coupe as well good question.
Old Jul 10, 2006 | 12:22 PM
trey.hutcheson's Avatar
The 05+ coupe/sedan 6MT's have what is referred to as the "revup" engine. This engine has several changes, including allegedly stronger rods, variable exhaust timing(in addition to intake), a higher redline, allegedly different ecu maps, and a different intake plenum.
Peak hp occurs at roughly the same rpm, but the revup keeps that peak all the way till redline(in stock form), whereas the non-revup drops power after 6200 or so rpms. The increased redline doesn't have anything to do with the increased peak hp.
You can't simply ad bolt ons or flash the ecu to get the revup motor. But don't be envious of the revup's hp; it also makes less torque than the standard package.
Old Jul 10, 2006 | 12:23 PM
Derek S's Avatar
i have a magazine that talks all about the G35 HP gain. i will post it up later.
Old Jul 10, 2006 | 12:36 PM
2FastG354U's Avatar
Trey, you are crazy knowledgeable about G35's!
Old Jul 10, 2006 | 02:41 PM
I'll take that as a compliment, and thank you, but I'm really only repeating what I've read elsewhere.
Old Jul 10, 2006 | 03:07 PM
Klubbheads's Avatar
https://g35driver.com/forums/showthr...ighlight=motor
Trey do u know what rpm do the 05-06 6mts put down the peak HP?
Old Jul 10, 2006 | 03:18 PM
I believe it's the same. Right at 6200 to 6300 rpms. Again, that's stock. The installation of the MREV causes a similar drop after peak as the non revup engine.
I am actually considering removing the mrev to see if it affects my times at all. The mrev has been a proven mod, but in my case, I just didn't see the same gains most others did.
Old Jul 10, 2006 | 06:57 PM
Neal376's Avatar
stronger rods?
from what I know, its only camshafts and a revised plenum.
Old Jul 10, 2006 | 07:05 PM
ttrank's Avatar
Grocery getter
Search. There was just a thread on this.
Old Jul 10, 2006 | 11:09 PM
DaveB's Avatar
Originally Posted by Neal376
stronger rods?
I believe the rods are the same, it's the rod bolts that are stronger. I know that a lot of Maxima guys with VQ30s that are revving to 7000+rpms specifically use Rev-Up rod bolts.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
TurTLe*
Sep 29, 2015 01:43 PM
