OFFSETS for staggered
Old Jul 20, 2006 | 01:00 AM
Texan1's Avatar
Q50 Red Sport 400 RWD
Originally Posted by QuadCam
not true. If it is lowered and aligned to factory specs, it will be very close. You will probably get a touch of rub on the fender lip....just a touch though.....and you'd have to hit a big dip in the road.
another thing to note is the tire. all tires have very different should profiles. A rounded shoulder is preferable for this setup!!! A square shouldered tire WILL rub.
that setup with a dunlop direzza or falken azenis and a prokit should not rub--especially if you are always driving with no adults in rear. These tires do have a rounded sidewall.
Should not is key, but thats what I have researched--as I have not pulled the trigger on staggereds yet.
Old Jul 20, 2006 | 05:51 AM
skeleton_cru's Avatar
Sedan
The Michelin Pilot Sport II tires have a fairly rounded shoulder as well.
Old Jul 31, 2006 | 10:17 AM
G35sedan03's Avatar
+35 offset on rear???
Guys i'm looking at purchasing a set of ADR M sport classics for the rear on 19x9.5 with a +35 offset. Will that fit the sedan fine with 275/30 tires? I believe it can without rolling fenders but i need to know for sure. Thanks for the help
Old Jul 31, 2006 | 01:25 PM
Endless G's Avatar
NEGATIVE on that , you WILL have to ROLL for sure!!! Max i have known is +38. But Shodog has +35 here and he got the Dunlop but he rolled it!!! Send him a PM
Old Aug 1, 2006 | 12:14 AM
sliderg35's Avatar
I'm running 245/275 no rubbing with three fat guys in the back even with the camber kit. +35, +48 and Toyo T1-R. Oh, did I mention I am also lowered on Eiback pro.
Old Aug 1, 2006 | 02:23 AM
ttrank's Avatar
Grocery getter
All the camber kits I know of bring the bottom of the wheel in so you have even less of a chance of rubbing.
Old Aug 1, 2006 | 04:52 AM
Sedan
You have 9.5/+48 in the rear right? He's asking about 9.5/+35 in the rear (which will definitely rub the fender).
Old Aug 1, 2006 | 10:35 AM
sliderg35's Avatar
Agreed... +35 even with skinny guys in the back will rub.
Old Aug 1, 2006 | 10:36 AM
sliderg35's Avatar
Correct... and when you bring the bottom in, the top moves out.
Old Aug 1, 2006 | 01:09 PM
G35sedan03's Avatar
All, thanks for the responses. Guess i have to look at something else.
Old Aug 1, 2006 | 04:06 PM
Kingfanpaul@sta's Avatar
i am going to have 35 offset in the back but in 18" wheels. After I roll fender will everything be cool? I'd still like to drop cuz there is still considerable gap, anyway to make that possible?
Old Aug 1, 2006 | 04:13 PM
vodkarocket's Avatar
Modded Member
Sure, stretch 245/40/18 tires on the back. That should work without rubbing...
Old Aug 10, 2006 | 07:55 PM
heyitzalex's Avatar
just go +40 in the rear and roll the fenders. thats what im doing
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
TurTLe*
Sep 29, 2015 01:43 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
