Camber is Important
Old Jul 18, 2006 | 04:07 AM
perry05G35's Avatar
Camber is Important
Yesterday I was at the dealer getting an oil change (18K) after my oil change I was told that all 4 of my tires are at 2/32 tread life and my steel belting are showing. I am running eibach pro kit springs and I didn't get the camber kit because I didn't think I needed it for a 1 inch drop. My 2002 Maxima had a 1 inch drop and I didn't need a camber kit to adjust my alignment either. Anyway to make a long story short get a camber kit regardless in the end I would have saved a lot of money instead of purchasing new tires I was qouted 1484.12 for new Toyos I found them cheaper of course but with shipping and labor it still works out to about the same. I ended up purchasing a set of M45/35 sport wheels and tires including tire pressure sensors on eBay with just 157 miles on them for 950.00! So there is a bright side to the story I plan on either mounting my Milanos on the tires or putting the M sport wheels tires on the car with spacers. Those of you with the M sport wheels PM me I need advice on spacers etc...
Old Jul 18, 2006 | 07:55 AM
razo168's Avatar
yea camber is important.. i didnt have enough money to get it when i got my new set of tires and its eating up the tires faster than i thought it would.. so my next mod will def. be a rear camber kit and also go get an alignment..
Old Jul 18, 2006 | 09:19 AM
Chico's Avatar
$1484 for Toyos? That is crazy expensive. I already rotated my tires inside / out but still had a lot of meat on them. Just did it to get an even "UNEVEN" wear. Just curious, what are your camber specs?
Old Jul 18, 2006 | 09:32 AM
ratm68's Avatar
Did you get allignment after the drop? Don't how it is with the sedan, but with my coupe on 350z h-tech, i was able to get within oem spec for the coupe. -1.3 degree for the front (which is the limit for negative camber) and -1.7 degree in the rear (which can go up to -2.0). That sucks you have to get new tire, your allignment must off been way off from the drop. Did you inspect the tires yourself? Dealers always exagerate to make a sale.
~Khoa
Old Jul 18, 2006 | 09:33 AM
da mayor's Avatar
just get the nitto neo-gens it does help with a little longer life out of the tire and is made for vehicles that have negative camber.
Old Jul 18, 2006 | 10:01 AM
Texasscout's Avatar
You say you are getting the "rear" kit, what about the front tires? Did they wear as much as the back?
I have a set of "un-revised" 2004 350Z springs I have yet to install (most everyone wants $400+ to do it, so I will do it myself), should I just wait until I get the kit(s)?
Old Jul 18, 2006 | 11:29 AM
vodkarocket's Avatar
Modded Member
Just out of curiousity, how long did your tires last?
Old Jul 18, 2006 | 11:30 AM
GLuXuRy's Avatar
just ordered my SPC this week... should be here in a couple of days... sorry to hear about your tires man
Old Jul 18, 2006 | 11:35 AM
ttrank's Avatar
Grocery getter
~Khoa
+1
Camber does wear out your tires but if your toe is off it will eat them alive.
The sedan does not have as aggressive camber specs as the coupe so I was not able to back within spec with H&R springs but I am close. The trick is to have your tires swapped every so often. Since mine are staggered I try to swap them every 5-6k.
Old Jul 18, 2006 | 12:14 PM
perry05G35's Avatar
I brought my wheels and tires at the 8K mile mark purchased on eBay the wheels tires had about 1000 mi on them when I brought them. I had my car lowered at 11K miles so from 11K to 18K the tires wore I was told that the front was the worse and the rear were not that far behind. When I got my car lowered an allignment was done and my tires were rotated during my 15K service I haven't checked the wheels out myself or gotten a second opinion yet. I found the eibach camber kit for 192.00 does anyone have experience or opinons on it? I also purchased M45/35 sport wheels and tires with sensors for 950.00 I figured I can either mount my Milanos on the tires and sell the M45/35 rims to break even or sell my Milanos.
Old Jul 18, 2006 | 03:05 PM
ratm68's Avatar
You said you got allignment when it was lowered. Just wanted to make sure it wasn't done right after install correct? If you bought your spring new, it takes 2-3 weeks for it completely settle. Just wanted to make sure b/c if you did get it alligned upon installation, in 2-3 weeks your allignment might be off. 7K miles isn't a lot to be wearing down tires, my camber actually didn't get effected much, it was my caster and toe that got knocked off from the springs. I would get a second opinion, take it to a wheel shop, and get a free allignment check.
~Khoa
Old Jul 18, 2006 | 04:57 PM
ttrank's Avatar
Grocery getter
I have never seen a shop that will do a free 4-wheel alingment check. Most of the time in doing it is in the set-up.
Old Jul 18, 2006 | 06:22 PM
perry05G35's Avatar
~Khoa
Good idea but I do believe the tires are worn from what I can see visually it looks like I have been driving on the tires for 40K instead of less than 10K. I never paid any attention to it until this week actually. I will get my allignment checked out once my next set of wheels and tires come in. I am not rich don't get me wrong but again I am hoping to recoupe some of my money by selling the milanos or M sport rims.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
wow600rr
Sep 28, 2015 11:50 AM
