Wind Noise
Old Oct 6, 2003 | 08:44 PM
LasPalmas's Avatar
Wind Noise
Just got our car about a month ago. Basically love it. One thing bothers me though: Quite a bit of wind noise at normal freeway speeds (65-75). Thought the car would be quieter. Does everyone experience this or do I have something that needs fixing? My 2001 Acura CL-S is a lot quieter, but doesn't handle quite as well.
'03 1/2 Prem/Performance Pkg/Navi
Old Oct 6, 2003 | 11:07 PM
rajanb's Avatar
Re: Wind Noise
Check out some discussion on this here wind noise (fresh alloy)
I had a bad mirror initially that was replaced under warranty. That helped a lot and the car is a LOT quieter, but not as quiet as say a Passat. There also seems to be some correlation between humidity and wind noise as well on cross winds.
One thing I tried and that seems to have helped is to push with your palm against the door jamb or window when driving. That seems to have seated the door a little better and made the car a little quieter.
Having said all that, most of my passengers can't seem to understand what I am talking about and find the car quiet enough. Other thing I realized that is on the G, you do 80 (or more) a lot more than you do on any other car. The G speedo is very accurate (Passat was about 5mph over at 60) so in other cars, the speedo may indicate 60 but you are only doing 55.
Hope that helps.
Old Apr 22, 2005 | 06:05 PM
TBone24's Avatar
Noisy car, I agree ... look into some dynamat or b-quiet to quiet things down, especially on the freeway
Old Apr 22, 2005 | 07:06 PM
transportchef's Avatar
Wind noise is the 2k2 maxima that I had. The G is very quiet coming from that car. So far the only noise is a low howl/wail from the windows. It has only occured a few times. Lasting a few secs in duration.
Old Apr 22, 2005 | 07:21 PM
ABQ_G35's Avatar
The only wind noise I get on mine, is just from the windshield, no air leak, just the aerodynamics, I don't see any way around that unless your windshield is almost flat, LOL!
Old Apr 23, 2005 | 07:22 PM
Vsix's Avatar
well, the G35 is alot more quiet than our A4 and Matrix. It is, ofcox, more quiet than my friend's Golf, Rav4, and X5 4.4i. However, the 4.4i is more comfortable...
Old Apr 23, 2005 | 08:07 PM
GeeWillikers's Avatar
Walking The Fine Line...
10X quieter than the 98 Maxima I came from. Wind noise is minimal.
Old Apr 23, 2005 | 10:43 PM
imnohero's Avatar
Most of the noise in my car at highway speed is road/tire noise. It's much louder than the wind.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Duffy25
Accessories
Oct 12, 2015 01:45 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
