Need Help On Removing Center Console On 05
Old Aug 2, 2006 | 08:43 PM
MARKRVA99's Avatar
I Just Bought A Short Shifter But I Can't Install It. It Seems The Center Console Won't Come Off. I'm Afraid To Put Too Much Pressure On It That I Might Break The Aluminium Trim Around The Shift Stalk. Can Anyone Help?
Old Aug 2, 2006 | 08:56 PM
zackt69's Avatar
rarejdm.com
Check out this post... it has the Service Manual for the 05 - shows where all the clips are. It's kind of nerve racking the first time you take the dash/console apart... but you'll see that most of it is held together by clips. There are a couple other posts with pics for installing the PAC ipod adaptor that might be helpful too.
https://g35driver.com/forums/showthr...service+manual
https://g35driver.com/forums/showthr...light=ipod+pac
Old Aug 3, 2006 | 07:59 PM
MARKRVA99's Avatar
Thanks Zackt69. I'll Check Out The Pdf And I'll Give An Update. Thanks Again.
Old Aug 3, 2006 | 10:40 PM
ttrank's Avatar
Grocery getter
I did an DD install on an 06' AT and you had to put some pressure on it to get it to unsnap.
g.spot
May 9, 2016 10:54 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
BradMD_96
Oct 6, 2015 09:31 AM
