Spark plug change?
Old Aug 3, 2006 | 12:19 AM
AuAltima3.5's Avatar
Spark plug change?
I want to change the plugs, since I have some new NGKs for the old VQ laying around. I figure at 54k it cant hurt to do.
I am too lazy to pop that engine cover off, but is it just going to be six coils staring at me? can I just yank those off and pull the plugs out? will I have to remove anything else?
The plug change on my alti was gonna be a pain, so I figure I should put this 60 bucks to a good cause.
Old Aug 3, 2006 | 12:37 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
You gotta take off the engine cover then pull off the upper and lower plenum's to get to the plugs.
-GP-
Old Aug 3, 2006 | 03:52 AM
bythabay's Avatar
-GP-
you're kidding.. right?
Old Aug 3, 2006 | 04:02 AM
bythabay's Avatar
don't know what you're talkin' about ... here are the instructions from the service manual:
1. Remove engine cover with power tool.
2. Remove air cleaner case and air duct (for ignition coil of left bank side).
3. Move aside harness, harness bracket, and hoses located above ignition coil.
4. Disconnect harness connector from ignition coil.
5. Remove ignition coil.
CAUTION:
Do not shock it.
INSTALLATION
Install in the reverse order of removal.
Old Aug 3, 2006 | 01:03 PM
ok nevermind. I just went out to my car and looked at it. Just take off the intake and the right side should be fully accessible. You'll have to move a few wires that are bolted down to get full access to the left side but that shouldnt be a problem. You should be able to change the plugs in less than 40 minutes if you know what you're doing.
-GP-
Old Aug 3, 2006 | 01:07 PM
bythabay's Avatar
-GP-
And if you don't know what you're doing, come over and I'll help you
Old Aug 3, 2006 | 01:12 PM
lol, i know what i'm doing. But i wont have to change my plugs for another
70K so i'm not worried about that.
-GP-
Old Aug 3, 2006 | 01:26 PM
bythabay's Avatar
I've been considering swapping mine out with some colder copper plugs to reduce pinging... any opinions on that?
Old Aug 3, 2006 | 01:50 PM
DieselX's Avatar
doo eet!
Old Aug 3, 2006 | 03:50 PM
Copper plugs will retain less heat, so 'downgrading' to a copper plug has its benefits in a ping prone car.
If you swithc to copper, you need to change them every 30k, or the gap will get a little nutty.
Old Aug 3, 2006 | 03:58 PM
ttrank's Avatar
Grocery getter
Change out your plugs for NGK PLFR6A-11's
That is the oem plug but 1 step colder. Just about all FI installs call for these plugs. If you still have pinging try to gap them a little less ~32 (stock is 44).
Old Oct 26, 2006 | 10:15 AM
b00stedjustin's Avatar
Wtf?
I thought that was only a turbo concern?
Old Oct 26, 2006 | 11:04 AM
bythabay's Avatar
If you read the service manual it states cooler plugs can be used if the engine experiences spark knock or you do extended highway driving. Infiniti specs three spark plug types for the VQ35DE as OEM.
Old Oct 26, 2006 | 12:25 PM
ttrank's Avatar
Grocery getter
You can have these problems NA too. It is a must if you go FI.
mtlruss
Dec 20, 2015 01:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
yassy
Aug 9, 2015 07:31 PM
wuppiedog
Aug 7, 2015 11:16 AM
