service engine light
Old Sep 1, 2006 | 01:29 PM
driguez's Avatar
Originally Posted by 1fastsedan
the scanner read throttle body problem, so we cleared it. but i noticed a small leak coming from my plenum again. so i have to fix this cause its going to throw a code again i am assuming.
all the scanner did was clear the code not fix the problem (ECU), do the battery disconnect reset, that fixed it up for me, my iddle was around 900-1,000 after i cleaned up the throttle body, very annoying btw...
Old Sep 1, 2006 | 01:35 PM
da mayor's Avatar
well there's a new bulletin that they should order a new throttle body if you need it since you have the code.
Old Sep 1, 2006 | 02:40 PM
1fastsedan's Avatar
i'll give it a shot, just picked up my plenum gasket ($30.00) once i fix the leak i will reset ecu. thanks
Old Sep 5, 2006 | 04:13 PM
1fastsedan's Avatar
fixed plenum leak and reset ecu. i reset the ecu on the first try even. will let you know if this has fixed the problem
Old Sep 5, 2006 | 04:16 PM
ttrank's Avatar
Grocery getter
Good luck.
Old Sep 5, 2006 | 06:14 PM
1fastsedan's Avatar
still having high idle problems after clearing ecu.
Old Sep 8, 2006 | 12:25 PM
1fastsedan's Avatar
the 12hr disconnect worked, everything is back to normal!
Old Sep 8, 2006 | 12:26 PM
driguez's Avatar
told ya!
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Ednica87
Sep 5, 2015 02:59 AM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
