Brake pad wear on 2006 sedans
Old Sep 28, 2006 | 03:13 PM
Ghaleon0721's Avatar
I've been doing some research on the G35 and it seems that alot of people with 03's and 04's (some '05's too) are experiencing abysmal brake pad life. I was wondering if people are still having this problem with '06's. I haven't found anyone in these, or other, forums complaining of this problem on an '06, but at the same time I can't find anything explaining what Nissan did to fix this issue.
I'm picking up a new '06 sedan 6mt in less than two hours and I would really like to know what I'm getting into.
Old Sep 28, 2006 | 03:27 PM
absolutg's Avatar
workin...
i haven't had any problems yet. i've got about 9500 miles on my car over the past 11 months
Old Sep 28, 2006 | 03:41 PM
chobble19's Avatar
get used to some sqeaking everytime the car sits for a bit after about 10k miles...mine does it everyday the first time i drive it and is now sqeaking throughout the day even with plenty of life left on the pads...bottom line is the pads suck but do work. i will be getting ceramics soon
Old Sep 28, 2006 | 04:48 PM
ttrank's Avatar
Grocery getter
Most of the problems were fixed on the 05's.
Old Sep 28, 2006 | 06:03 PM
Clean G 4D's Avatar
05 with approx 13k miles... no problems so far.
One reason you dont see any complaints on 06's is because most of these people have not put enough miles on the car to notice premature wear.
Plus, 05-06 has bigger breaks. I am no brake expert, but the bigger breaks would mean less overall work done by the pads (larger surface area) = they last longer.
Old Sep 28, 2006 | 06:31 PM
Garyv01's Avatar
i have an 06x with 17,000 miles...brakes suk at this point...lots of squeaking especially when hot, also its kinda odd but my backs are extremly worn where as the front seem to have decent amount of pad left
Old Sep 28, 2006 | 07:59 PM
esfoad's Avatar
I have the PBR Metal Matrix pads on my 05X with the "small" brakes. I now have 14K miles on them. They are great. Still about 75% pad life left (around 7mm) all around, hardly any brake dust and squeal about 5% of the time. Can't figure a pattern to the squeal except it's only when I have light pressure on the brakes. I highly recommend these.
Old Oct 1, 2006 | 12:55 PM
bythabay's Avatar
I would make sure to listen for any unusual pinging/knocking noises from the engine under load.
nickmcc123
Lights
Oct 7, 2017 12:18 AM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
emorehs
Jul 17, 2015 09:45 AM
