HELP!!! Decide between Z-TUBE+POP CHARGER and INJEN CAI SYSTEM
i had an injen, but switched to a JWT/z-tube.
reason was, I could change the filter on the JWT a lot faster =D.
if you do get either, make sure you give it sufficient clearance to the AC line or you will be hitting yourself with a hammer when you have to replace the whole system.
Originally Posted by 2006_G_coupe
Neither..Just stay stock with a drop in filter..
It's generally accepted that intakes don't do squat for these cars. If all you want is noise, why pay $250 for it? By yourself the Z-tube and remove the over radiator air snorkel and the Power Duct cover. You'll get EXACTLY the same induction noise.
i had the pop charger w/heat shield plus the z tube..i live in south texas and it gets damn hot over here so the intake wasnt really efficient...trust me the heat shield doesnt do squat...anyway i put my stock air box back in with kn filter plus the ztube and sound is pretty good...then i took off the "power duct" and wow it sounds awesome!...try that combo first before you spend the money on the intake..our intake is good stock so i wouldnt change it out..i actually noticed the car had more low end grunt as opposed to the pop charger combo...
Originally Posted by G35_TX
Stillen has proven to wrok on this car. Please don't believe someone who has never tested products before on his own car.
.....or are you going to post a dyno proving your point?
LOL here we go again. Threating to post your unreliable other persons dyno that was not in a controlled enviroment and uncontrolled situations. We have been through this before many times and people are tired of hearing it. Others have posted gains and dynos with controlled conditions. Even Tony has this info if anyone wants it. DaveB. You have yet yourself to test a intake on your car period. EOS. Until then you need to keep your misinformed comments to yourself.
Originally Posted by Genius668
I am having hard time to decide between these two intake systems. After reading all forums and done some research, now I am down to these two systems to decide which one to buy.
1. Z-TUBE + JWT POP CHARGER w/HEAT SHEILD
2. INJEN RD1992 COLD AIR INTAKE
Any comments between these two systems? Any advantage/disadvantage between these two?
lol I am also going with number one now
Its utah so we always have rain and snow so its an easy choice
Stillen intake dyno, before and after, no gain
https://g35driver.com/forums/showthr...illen+CAI+dyno
