Noise when brakes are applied
Old Oct 4, 2006 | 09:41 AM
brdavis9's Avatar
Hey there,
I have a 2003.5 sedan 5AT... When I'm in D and I come to a stop, there's a noise that sounds like something vibrating or pulsing but it's not in the pedal. It sounds like its coming from the front of the engine bay on the driver's side and when you put your ear up to the fender it gets louder. When I release the pedal, the noise goes away. Also, it won't make the noise when in any other transmission gear. I bled my brakes thinking it was the brake booster or something...the noise remained but my pedal did get tighter. I also flushed my coolant bc it needed it, and that didn't have any effect on it I don't think. I can't see how the radiator or water pump or thermostat would have anything to do with it, bc it made this noise before and after the coolant flush also... Thanks for any help!
-Brian
Old Oct 4, 2006 | 09:56 AM
g35rcr's Avatar
check your bolts on your wheels
Old Oct 4, 2006 | 03:00 PM
brdavis9's Avatar
umm my lugnuts are plenty tight... the car wouldn't ride like silk and it would shudder alot if they were loose. do you mean some other bolt?
brdavis9's Avatar
PS- the noise is only audible when the car is stopped, not driving
Old Oct 4, 2006 | 09:42 PM
RetAF's Avatar
ABS Pump, maybe???
Old Oct 4, 2006 | 10:58 PM
AgentAero04's Avatar
Originally Posted by RetAF
ABS Pump, maybe???
Or ABS sensor
Old Oct 5, 2006 | 09:08 AM
g35rcr's Avatar
i had loose lugnuts, not loose enough to wabble but it would shudder when the brakes were hit, look at your rotor are there any grooves like something cutting into the rotor from the pad?
Old Oct 5, 2006 | 11:56 AM
brdavis9's Avatar
yeah i'm thinking something with the ABS pump too but its weird how its only after I'm at a complete stop and only when the trans is in D. It's not the pads or rotors, they're cool and don't make noise or shudder.
Old Jan 1, 2010 | 07:54 PM
iafzal's Avatar
did you ever find the cause for this?
I think I have the same problem with G35 sedan. When I am stopped with my foot on the brake and in D I can hear this noise kind of like tapping which comes and goes. It is gone if I change the gear into N. Could it be the crank shaft?
Old Nov 1, 2012 | 10:05 AM
K.C's Avatar
K.C
BUMP FOR SOLUTION! Im in the same boat as (iafzal)
Old Nov 13, 2012 | 04:06 PM
K.C's Avatar
K.C
bump for some info.
Old Nov 14, 2012 | 07:21 AM
Mustang5L5's Avatar
Catalytic Converter Heat Shields
snic09
Nov 8, 2017 01:46 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
rping
Jul 26, 2015 09:53 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
papo020
Jul 17, 2015 10:30 PM
