maximum tire size for 17" rims
Old Oct 19, 2006 | 09:51 PM
mwhitney's Avatar
what is the maximum tire size I can use on my 2004 G35x sedan? They came with 215/55 - 17. According to Tirerack.com I may be able to go to 235/50's.
I believe the diameter is the same, but I don't know if there's enough clearance in the wheel wells, etc..
Old Oct 19, 2006 | 09:56 PM
ttrank's Avatar
Grocery getter
You should be able to run a 235/50 no problem. They might be a little larger diameter but not enough to cause any problems.
Old Oct 19, 2006 | 10:08 PM
Klubbheads's Avatar
im runnning 235/50/17 right now on the stock 17 inch rim. No problems.
Old Oct 20, 2006 | 09:12 AM
infini_'s Avatar
Klubbheads have you noticed difference in acceleration/cornering/handling etc with broader tires?
Old Oct 20, 2006 | 10:53 AM
TigerMike's Avatar
This past summer, I had 235/50 17 tires installed on my G. Absolutely no problems with fitament whatsoever. Handling/cornering seems better, but this is probably more a function of the type of tire I put on (a high performance summer, versus those crappy and utterly worthless stock EL42s).
That size is the largest I'd personally put on the stock rim. I do really like the larger/wider look though. Gives the car a sportier look.
Old Oct 20, 2006 | 11:32 AM
Klubbheads's Avatar
well when i changed the tires, i did my whole suspension with it. But that 20 miles i drove to the shop i noticed more grip and better balance than stock.
I have 225/50/17 in the front and 235/50/17 in the rear with goodyear eagle f1 dsg 3 tires. as far as acceleration, there was no difference.
Old Oct 20, 2006 | 11:43 AM
infini_'s Avatar
225/50/17 in the front.... .... interesting... so your car is about half inch lower from the front as compared to the rear.
Old Oct 20, 2006 | 02:55 PM
cato's Avatar
SouthernComfort Moderator
235X50 fits the stock rims just fine. They bulge a bit. When I put those same tires on my new 5Zigen 17X8 wheels, they fit perfectly.
Old Oct 21, 2006 | 01:51 AM
OCG35's Avatar
I'm doing the same thing... 235/50/17 are virtually identical in circumference,diameter and speedo as stock 215/15/17.
The question I have is Goodyear F1, Toyo T1R, or Kumho ASX the way to go???… The answer is obvious in order of question… but so is price… Does anyone have a good reason to spend $$$ vs $$ vs $???
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
paolojericho11
Sep 11, 2015 07:08 AM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
