Who's the fastest F1 G35x???
Old Feb 10, 2007 | 04:10 PM
  #31
DP03's Avatar
Originally Posted by ma_sha1
Thanks, Xman,
That was way better than I thought, I would have been happy with low 13th.
I see many >400 whp TT can't get into 12s due to problem putting the power down with only 2 wheels going & even bigh wide tires is not enough. I am going the other way, I will try to put on my Forged 17 with stock 215/55 rubber next time, that's 8lb ligher than my PIAA set-up per corner. Im thinking that'll be another 0.2" right there, no need for drag rubber for the AWD.
I am just still so paranoid about the AFR. My WOT AFR is still seems to be in the 12/13 area. Won't be running another 1/4 mile until I get a Dyno & make sure everything is where it should be. Can't afford to ca-boom my daily driver.
A car the weight of a G with over 400 whp better be in the 12's. My portly (4200 lbs without driver) Charger SRT8 425 crank hp car, did 13.1 first time at the track. Rear tires are only 255's. And SRT8's (except for AWD Jeep) don't do well in the 60' due to tall (3.08) gearing. High 1.9's or 2.0's are typical. I would expect a lighter car with more whp to be well into the 12's no problem.
Old Feb 10, 2007 | 05:25 PM
  #32
Neal376's Avatar
hey ma sha, 17" fits over your BBK? if so, i think i need to purchase a set
Old Feb 10, 2007 | 07:25 PM
  #33
ma_sha1's Avatar
Neal,
I got these Roja Forged wheels, only 15lb each, didn't really get to use them yet. the tire is the 2005 G35x OEM 215/55 17 stock rubber, had about 3-500 miles. They fit my BBK. (With spacer same as my PIAA).
They are 17x7 42 off set.
I am thinking selling it after this spring, (I got them to help me getting into 12s) , but I need to keep one as full size spare as the donut can't fit the BBK. I may also need to keep it for inspection use, one place won't give me sticker with the PIAA.
Old Feb 10, 2007 | 07:29 PM
  #34
Neal376's Avatar
Neal,
I got these Roja Forged wheels only 15lb each, didn't really get to use them yet. the tire is the 2005 G35x OEM 215/55 17 stock rubber, had about 3-500 miles. They fit my BBK. (With spacer same as my PIAA).
I am thinking selling it after this spring, but I need to keep one as full size spare.
also I am afraid not able to pass inspection with the plus size PIAA, so tough call.
you cant pass inspection with the PIAA?
Old Feb 10, 2007 | 07:36 PM
  #35
ma_sha1's Avatar
A meineke muffler idot says new Maine Law, rubber has to be exact as the door sticker i.e. 215/55 17. I had to go elsewhere to get my sticker. Idiots.
Old Feb 10, 2007 | 08:30 PM
  #36
Neal376's Avatar
whhhhhhhhhhhaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa???
thats psychotic!
Old Feb 11, 2007 | 12:56 AM
  #37
G-Mony's Avatar
My first run after fixing the AFR & upgraded the VB:
This is my first & only run without hitting rev. limiter.
Recorded using my G-timer, which was carefully calibrated at track to be within 0.1" vs. slip.
1/4 mile ET: 12.92"
60 ft: 1.95"
0-60: 4.40"
Max HP: 325 whp
Max Speed 107 mph
Temp. 20 F
225/45/R18 Toyo Proxy 4 All season, 32 PSI.
VDC Off, Air/Heat Off, Manual Shift.
yah nice time!!:0
one of these days i gotta go track mine to see what she can do
Old Feb 21, 2007 | 01:43 PM
  #38
G35x-06's Avatar
sorry to post and bust in on the thread but can anyone please tell me which vortech supercharger would fit an 06X if possible with the part number also thanks
Old Feb 21, 2007 | 01:54 PM
  #39
DaveB's Avatar
1/4 mile ET: 12.92"
60 ft: 1.95"
0-60: 4.40"
Max HP: 325 whp
Max Speed 107 mph
Temp. 20 F
There is no problem launching with the 225 all season, thanks to the AWD.
I shifted early at: 5000, 6000, 6000 to avoid hitting rev limitor.
There are room left for shifting, So I'll try 5500, 6000, 6300 next time.
The car feels like a rocket, especially the launch is awsome!
Besides S/C, only other performance mods are sports suspension, light weight BBK & Stillen true dual.
As soon as Epping NH drag strip open on April 1, I'll head down there for some slips. Last year just about every car out there beat me (I was running 14.8-14.9 all day), It's time for revenge!
Just for reference, my best G-timer run before S/C was 14.4, max hp 230 whp, max speed 95 mph, also done in cold winter. The HKS S/C improved ~1.5" for the quarter mile.
My guess is 13.5@104mph at the track assuming you do no other mods.
malx
Archived Sales
Aug 30, 2006 05:05 PM
malx
Aug 30, 2006 03:51 PM
Neal376
May 25, 2006 12:38 AM
callawayc7
Feb 15, 2006 09:59 AM
ChicagoX
Nov 13, 2004 12:46 AM
