View Poll Results: Which true dual exhaust system would you pick for G35 Sedan?
Stillen
74
61.67%
Borla
46
38.33%
Voters: 120. You may not vote on this poll
Borla or Stillen True dual Exhaust?/
Originally Posted by machavez702
The Stillen muffler is straight through and the resonators are bigger so the limit of flow for the Stillen is the sectional area of the 2 pipes. In general, you just use the section of the diameter to compare pipe flow for exhaust. I know the stock muffler isn't straight through but for the purpose of flow comparison, just use the area of the pipe's section.
In that case I would estimate the Stillen to be a little higher. Maybe 55-60%. Does anyone know the pipe size on the Stillen? I would guess 2 1/2" I believe the Borla is 2 1/4".
^^^+1, Stillen pipes is 2 1/2" all the way.
Has anyone look inside the Borla first muffler/resonnator? Is it a straight through with perforation, or does it has a crossover (H-pipe)? Crossover help equalize the exhaust pressure, improving flow. Kinda like scavanging effect.
Off topic, but on the Z32 w/o crossover, it sound like two 3 cylinder engine. Kinda like first gen Viper w/side pipe, two 5 cylinder. Both sound like @ss. This doesn't apply to the Borla as much because the two banks share the same muffler.
Originally Posted by Neal376
Borla will hit just fine. All you need is the muffler bracket sold my most G35 Vendors
Borla vs Stillen vs stock
Perhaps you already have an answer. The Stillen true dual exhaust weighs 13 lbs. It will increase horse power 21-23 and torque 21-23 foot pounds. The Stillen exhaust that I have for sale is stainless steel, a true dual with an X pipe to balance pressure.
Wow 13lbs and 21-23 hp and ftlb gains!
So that's why you are selling yours?
https://g35driver.com/forums/showthr...01#post1498301
I say neither. Wait another month or so for the Fast Intentions sedan system to come out. Its going to be bomb! Be patient. FI is a kick-*** company with great customer support and sweet systems
