Compression Rod problem - Anyone get satistfaction from Infiniti?
Old Nov 15, 2006 | 11:27 AM
DaveB's Avatar
It is dissappointing that this is an issue with the car. The bushings on this car are pretty stiff for OEM and they help the car perform like it does. As the bushings age, they loose they're natural lubrication and they will creak. The noise I hear sounds exactly like stiff aftermarket poly bushings that aren't lubed well. It is a manufacturing defect, but I really see no way on how to fix this unless they develop serviceable grease bushings.
Old Nov 15, 2006 | 12:57 PM
bman5150's Avatar
Just so I have this straight. . .there are no grease zirk fittings on the bushing joints/lower control arms? Does this affect all 1st Gen G35s (seems it does but I want to conrfirm.)
Wonder if the 07s have grease fittings. . .
Thanks!
Old Nov 15, 2006 | 01:42 PM
jimmyc13's Avatar
Originally Posted by Noremac
I've read and contributed to many of the past threads on the Compression Rod problem (causing a creaking, crunching sound from the front end).
I'm getting totally annoyed by it again, and my dealer (after replacing the parts once) is now giving me the "cannot replicate" nonsense. Replacing the rods/bushings clearly fixes the problem, but it's only temporary.
Has anyone successfully gotten Infiniti to respond to this problem? I know some of you opened customer service cases. How about getting another dealer in the Wash DC area to be responsive? (my obstinate dealer is Passport).
Based on my numerous times to the dealership for various rattles & squeaks (including the compression rod one), the only way to truly replicate the problem & get them to witness it is to have the head service technician go for a ride in your car with you (with you driving) as you know what types of roads & maneuvers will make your car squeak....don't leave your car or let HIM leave your car until he says he hears it! Don't just sit with a service tech, tell him your issues & walk away for the day.
I cannot believe you would have to do the corporate thing to get this resolved...that's BS IMO!!
Old Nov 15, 2006 | 05:09 PM
DaveB's Avatar
Thanks!
Most companies are getting away from serviceable bushings due to environmental regs.
Old Dec 12, 2006 | 02:37 PM
Mod Friendly's Avatar
Compression rod or any other suspension piece do not have grease fittings on them to relube it. The compression rod is more likely a candidate for the g35 drift to the right while driving than anything else. If you have the car aligned after 15k or so and it does hold an alignment thats one key defect in it starting to go out. As for the noise it was posted earlier if the bushing starts to dry out it will creek a bit, sometimes we can get it to act up at the dealer and sometimes we cant.
MyfistYourFace
Aug 8, 2015 11:58 AM
kinetek
Aug 3, 2015 04:25 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
LoSt180
Jul 15, 2015 08:31 AM
