brake and slip light on.....
Old Nov 7, 2006 | 06:40 PM
hongmin's Avatar
everytime i floor the gas from first gear the freakin brake and the slip lights come on!!!!!!
WTF is the problem here??!!! heeeeeelp meeee!!~~~
Old Nov 7, 2006 | 06:48 PM
Jeff92se's Avatar
Red Card Crew
Inspect the brake fluid level. If low, I'd suspect your brake pads are getting worn.
Old Nov 7, 2006 | 06:51 PM
nghiars's Avatar
are your tires ok... the slip might light up because the VDC is going off due to uneven tires/wear... not sure but good luck
Old Nov 7, 2006 | 09:07 PM
NG35S's Avatar
there is a recall on the break light switch i dont remember if the slip comes on also neways id take it in to the dealer.
Old Nov 8, 2006 | 07:53 PM
hongmin's Avatar
thanks guys!~!
Old Nov 10, 2006 | 02:11 AM
Cobra-2-G's Avatar
Fill the fluid to the max line first and restart the car. Pump the break pedal to put fluid into the lines and also go around and check for any leaks. The shop I went to that replaced my pad forgot to close a bleed line all the way.
Old Nov 13, 2006 | 01:09 PM
ttrank's Avatar
Grocery getter
All three of my lights just came on. (SLIP, VDC, ABS) I don't think it is the TB sensor because the car still drives perfect. I'm going to top off the brake fluid and see if that helps. If not, on to the dealer...
Old Nov 13, 2006 | 02:16 PM
excluesiveonez's Avatar
i had the prob on my 05x... brakes look good... fronts were replaced like 4k miles ago, rears are fine.
topped off with brake fluid and was good to go... found that out with the search button!
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
