ami i going crazy, or is this normal???
Old Nov 18, 2006 | 10:32 PM
thintzen's Avatar
is it just me, or has anyone encountered this problem. when they start their cars (2003 g sedan in specific) you hear this high pitch whine, and as the car cools down it goes away. the only reaosn i aksed is that i have 2 amps in the car, one for subs and one for interiors. and with the interior amp, this whine persists as i accelerate. however, when i changed interior amps, this whine noise is only present as the car is warming up or just started...it then goes away completely (with the new amp installed) is this initial engine whine normal???
i dont have a problem with it now becasue my alternator whine is gone being that i'm using a differernt, amp, but should i be concerned???
Old Nov 18, 2006 | 11:11 PM
ttrank's Avatar
Grocery getter
It could be the amp warming up too.
Old Nov 19, 2006 | 05:41 AM
350.GT's Avatar
the reason why you have engine noise is cause you have two amp. and the way the audio shop or your self ran the wires for the system or cause your RCA are bad. you can just buy a sound filter and your prob. will be gone.
Old Nov 19, 2006 | 04:44 PM
ttrank's Avatar
Grocery getter
OR just run the RCA's away from the power wires.
Old Nov 20, 2006 | 11:41 PM
kwiniarz's Avatar
sounds like you didn't ground your amp properly, try replacing the ground wires
Old Nov 20, 2006 | 11:57 PM
Mark 18578's Avatar
Grounding Issues
Best bet is you have a bad ground.
Old Nov 21, 2006 | 06:31 AM
chinee's Avatar
Just get a filter... maybe two... problem solved.
Old Nov 21, 2006 | 12:30 PM
ttrank's Avatar
Grocery getter
^^^ Why not three
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
BradMD_96
Oct 6, 2015 09:31 AM
aaron3719
Sep 29, 2015 10:12 AM
