tire pressure sensor warning light
Old Nov 26, 2006 | 06:43 PM
IP05G35's Avatar
One of my front tires has a slow leak for some reason and the PSI was around 20. I set the front tires to 35psi each and after driving for a few days the warning light will not go off. Any ideas?
Old Nov 26, 2006 | 07:20 PM
RRF985's Avatar
It will go off eventually. It will probably just take a lot of time. Having said that, my mom's went on the other day so when I was hope i filled the tires to 33 all around and the light went off the next day.
Old Nov 26, 2006 | 07:46 PM
ttrank's Avatar
Grocery getter
Some people say it takes a while to go off for them. Mine has always gone off within 5-10 minutes.
Old Nov 26, 2006 | 08:23 PM
jovo517's Avatar
after driving on the highway for a hour or so my light goes on but i check the tires and there fine n e one no wat that could be
Old Nov 26, 2006 | 10:52 PM
ttrank's Avatar
Grocery getter
Maybe a sensor is going out. If you can take it to the dealer when the light is on and have them read the code.
Old Nov 26, 2006 | 10:53 PM
akachi's Avatar
mine went off right after i filled it up to 40psi...
i have to put in air every 2-3 weeks =(
Old Nov 26, 2006 | 11:16 PM
ttrank's Avatar
Grocery getter
Time for a new tire.
Old Nov 27, 2006 | 10:01 AM
Philly_G35's Avatar
You don't have the sensors in your aftermarket wheels so the TPS comes on after a while.
Muski_G
Dec 1, 2023 11:11 AM
tal1412
Nov 28, 2022 09:25 AM
mjfenix
Jul 17, 2015 02:07 PM
Jadenkid22
Jul 14, 2015 12:33 AM
