Best "Big Brake" package?
Old Nov 28, 2006 | 12:45 PM
Graphite05G's Avatar
The RV Specialist
Hey guys, I'm trying to get an idea of what manufacture of Brake System people have on their sedans. Give me some idea of what you impressions are of your particular kit. Just wanting to do a little research before I buy....thanks....Ken
Old Nov 28, 2006 | 01:43 PM
ttrank's Avatar
Grocery getter
IMO the best BBK out there is still the Brembo 6-pot(f), 4-pot(r). But it is overkill for mostly street driving with some track. That is a great all track kit.
You have tons of options but it depends on what you want it for?
Just make sure you get wheels that will clear the caliper!
I have the Racing Brake 4-pot front BBK and oem caliper rear 13" rotors. The kit is awesome for the money and I would get it all over again. I got mine back when they first came out and were giving ~25-30% off for forum members. They still offer 10% off and their pricing is already some of the best on the market.
Old Nov 28, 2006 | 03:37 PM
hayaku's Avatar
I think the same kit will fit both the sedan and the coupe if I'm not mistaken. I've got the stoptech 13" kit all around and I'm really happy with it both on and off the track. make sure to check pad availability for whichever kit you buy to make sure you have options for both the street and track (if you plan to track). Wilwoods are also pretty good from what I've seen and are typically cheaper than most other brake kits out there. I personally went with stoptech since there's a lot of good feedback about stoptech on these forums and their headquarters is only a couple miles from my house.
Old Nov 28, 2006 | 07:11 PM
EverythingG35's Avatar
I've received good feedback on both the AP Racing and Stoptech kits.
Best really depends on your budget and intentions with the car. Many people will argue that for a street car any of these BBK's are extreme overkill and for a track car all you really need is a set of high temp pads and fluid (such as hawk blues w/ Motul fluid). However, those upgrades don't look nearly as sexy as a BABK behind a nice set of wheels and the pads would have to be swapped out once at the track, so it's a lot more work too.
___________________
Justin
Old Nov 28, 2006 | 08:19 PM
ttrank's Avatar
Grocery getter
^ and ^^ Good point on the fluid and I forgot about Wilwood.
I got SS lines and a Motul fluid flush with my BBK. That is an inexpensive addition that you should do for those track/mountain runs.
The Wilwood kit is a great performing lower cost add-on as well.
And yes the same kits fit the sedan as the coupe and 350Z. Again just make sure they clear your wheels.
Old Nov 28, 2006 | 08:38 PM
hayaku's Avatar
yeah I second on the fluid. The reason I upgraded brakes was because I cooked my stock brakes on my first track event. It was my own fault for doing too many hot laps without using a high temp fluid and street pads. On a side note, if you go hard on your brakes, your rears will fail before your fronts. I guess our cars have a rear bias or something, but I've talked to other people who tore up their rear brakes on the track while the fronts still held up.
I'm using Motul RBF600 now in my Stoptech setup and I love it. If you want more info about general brake technology and the basics behind how a brake system works, checkout stoptechs website and read their white papers. You'll find a lot of good general brake information not necessarily about their own products.
Old Nov 28, 2006 | 09:13 PM
G35Lin's Avatar
Multi-Spoked Mod
Endlesssss
Old Nov 28, 2006 | 10:50 PM
G35Papa's Avatar
I am also in the market for a set of BBKs. I am considering getting the Stoptechs (have a set of front OEM replacement rotors now with Hawks pads).
I was considering the Racing Brakes but they don't apper to have a complete matching set for the sedan (front drilled/slotted, rears only slotted) or maybe I am missing something?
Keep this thread going. I am curious to see what others are running as well. Pics would be great too
Old Nov 28, 2006 | 11:57 PM
ttrank's Avatar
Grocery getter
You are right on the RB. The rear kit is only slotted.
Stoptech is great but quite expensive.
Old Nov 29, 2006 | 12:04 AM
G35Papa's Avatar
Yeah, not done doing my research yet. Looking at all the rest too....Wilwood, AP racing....staying away from Endless and Brembo...too rich for my blood.
Old Nov 29, 2006 | 02:14 AM
jran76's Avatar
I am biased, but I do not think you can beat the performance and service of Stoptech. Top notch....
Old Nov 29, 2006 | 02:16 AM
Calvin's Avatar
Overglorified Altima
Originally Posted by G35Lin
Endlesssss
++1
Old Nov 29, 2006 | 02:58 AM
G35Papa's Avatar
Throw up some pics...please
Old Nov 29, 2006 | 08:51 AM
cato's Avatar
SouthernComfort Moderator
Old Nov 29, 2006 | 12:44 PM
ma_sha1's Avatar
Another Wiwood BBK for Sedan
