Staggered Tires on Sedan??
Old 12-22-2006, 03:47 AM
Klubbheads's Avatar
Originally Posted by phonedrn8
stay the same all around
may i ask y?
Old 12-22-2006, 06:45 AM
bowzer's Avatar
Ok, thanks for the help. I guess I will have to look at some diff wheels than the two I was looking at.
I've got 18x8 right now, looking for something a little more aggressive.
Any chance I could fit an 18x9 in the rear with a 38mm offset?
Old 12-22-2006, 09:34 AM
ttrank's Avatar
Grocery getter
Originally Posted by perry05G35
38 in the front will work fine but 40 in the rear will stick out too much if you have a 9.5" rim it would work with an 8.5 but that wouldn't be an aggressive staggarded setup. You are better off getting a +45 in the rear
If you are willing to roll your fenders a +40 in the rear will be fine. I have 10" +40 on my rears and the do not rub.
Old 12-22-2006, 10:54 AM
bowzer's Avatar
ok, at least i know that at +40 it's a possibility w/9.5 and rolled fenders
Old 12-22-2006, 02:50 PM
shodog's Avatar
+35 is do able if you roll your fenders but if you can find a +40-+45 you would be better off.
Old 12-22-2006, 03:02 PM
Klubbheads's Avatar
+33 is the coupe 8.5 wheel offset and i have no rubbing issues with fenders shaved.
Old 12-24-2006, 01:41 PM
sliderg35's Avatar
I'm running 275/35/19 (rear) with +48 offset. No rolling or rubbing.
Old 12-24-2006, 05:16 PM
GeeDM's Avatar
What Kit is that you are rocking????
Old 12-24-2006, 05:46 PM
sliderg35's Avatar
It's an authentic Gialla - straight from Japan. It took 3 months to get the sides! I get a lot of looks with this setup.
Old 12-24-2006, 06:09 PM
psedog's Avatar
Back in SD**
Do you have other pics of it?
Edit: Is that the Gialla Corsa kit?
Old 12-24-2006, 09:35 PM
sliderg35's Avatar
Sure, the transformation is documented here... http://www.comtech.ws/g35/Web/MyGiallaFull2.jpg
I think the "Corsa" kit is for the coupe. The Sedan kit is just "Gialla".
Old 12-24-2006, 10:59 PM
ttrank's Avatar
Grocery getter
Sorry, not feeling the kit. Does not fit the lines of the G.
vitamin.v
11-07-2019 06:10 PM
yellowshirt
Wheels & Tires CDN
04-08-2018 06:09 PM
multimut
Wheels & Tires CDN
04-08-2018 06:07 PM
bu villain
19 Inch
11-15-2015 09:23 PM
BlackGee35
07-31-2015 11:04 AM
Quick Reply: Staggered Tires on Sedan??
