Spring Installation
Old Dec 12, 2006 | 12:11 PM
Neal376's Avatar
Spring Installation
Spring Installation
400 (horrible) highway miles
Equals
GET YOUR CARS ALLIGNED
here is the run down
its difficult to understand...
lowered car on 350z springs = excessive neg camb (on axis pentas 19ix8.5).
neg camb adjusted w/ neg camb kit + allignment
raised car back to stock w/o allignment = excessive POSITIVE camber
equals The results in the pictures!!!
Old Dec 12, 2006 | 12:19 PM
jameyb's Avatar
Wow, you did your springs in a parking lot and 400 miles caused that much uneven wear on your tires?
Holy cow!
Old Dec 12, 2006 | 12:21 PM
MrBillMartin's Avatar
dunno if an allignement would do much help with that. you need a camber kit, jsut as i do
Old Dec 12, 2006 | 12:24 PM
akuma's Avatar
what you dropping it with??
Old Dec 12, 2006 | 12:25 PM
seddon's Avatar
Neal the Z springs did that. I thought you bought a camber kit to fit it.
Old Dec 12, 2006 | 12:28 PM
Neal376's Avatar
yea i had a camber kit...
what happened was I had 350z suspension on my G35 w/ axis pentas.
trying to experiment (since the rear was waaaay lower than the front) I put sedan springs in the rear and it evened it out a bit (gave it a / look). I didnt like it, so I thought I would swap back to 350z and install 350z shocks (hoping that would even it out). At the same time, I swapped for my winter/all season tires
and it did....but the 400 miles I had the sedan springs resulted in the uneven ware you see. Yea, I have a camber kit/toe kit and everything
Old Dec 12, 2006 | 12:29 PM
DieselX's Avatar
Whatttt?!?!
No way the springs did that, you must have messed something up. How many people on this board put on Z springs and nobody comes back with those results!
Old Dec 12, 2006 | 12:31 PM
Neal376's Avatar
Originally Posted by DieselX
Whatttt?!?!
no no no non no!!!
it wasnt Z springs!!!
I mixed springs up! I used z's in the front and stockers in the rear!! and because the car was previously alligned to 19 inch + 350z springs...it just could not handle the new specs at all
its my fault, not the Z springs!
lowered car on 350z springs = excessive neg camb.
neg camb adjusted
raised car back to stock = excessive POSITIVE camb
Old Dec 12, 2006 | 12:32 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
uhhhhhh, did you get an alignment to dial in the camber/toe kit?! there's not way Z springs would do that in 400 miles if the alignment was in spec. I'm on tien basics dropped about 1.7/1.3 and my tires arent even starting to show camber wear after 2500 miles.
-GP-
Old Dec 12, 2006 | 12:34 PM
DieselX's Avatar
Yea I get it now, should've said that in your first post.
Old Dec 12, 2006 | 12:37 PM
Neal376's Avatar
bahahahahha!!!
i never said anything about z springs in my first post!
everyone just assumed I did have Z springs!!! bhhahhaa
Old Dec 12, 2006 | 12:45 PM
az1anbeethoven's Avatar
damn...thats some irregular wear dood...i have the z suspension with 20s and do not show any camber wear after 6k miles...and im too lazy to get an alignment...just waiting to wear these tires out so i can slap on some better ones...
Old Dec 12, 2006 | 12:50 PM
Neal376's Avatar
its gonna cost me about 300 bucks to replace those not too awful
im sure now that my 350z springs are back on, the car should be close to or back to spec. it handles like a champ again!
Old Dec 12, 2006 | 02:24 PM
ashish's Avatar
Why not get some energy suspension spacers for the rear to bring it up a little bit or coupe rears?
Old Dec 12, 2006 | 02:42 PM
Neal376's Avatar
for some strange reason, the 350z shocks evened it out
