She has twins, greddy twins that is...
Old Jan 23, 2009 | 07:55 PM
  #1606
infinus's Avatar
Originally Posted by ttrank
Yes you are... and should be.
Did you do the break in yet?
Yeah I did it on the way home on grand ave, got a few looks from oncoming traffic especially when the smoke came out Gotta go on another drive to see how they hold up, that and I switched the sways to hard all around, should be fun
Also I found a guy to swap the 3.5 gears so I should have that within a few weeks.
Old Jan 23, 2009 | 07:57 PM
  #1607
infinus's Avatar
Cosmin (Infinus) has an 05 coupe.
What did you notice?
They are heavier but I didn't notice much on acceleration, but then again I ditched the spare tire too since it wont fit.
Old Jan 23, 2009 | 09:11 PM
  #1608
ttrank's Avatar
Grocery getter
Originally Posted by OCG35
you have a couple more hp than me to accommodate though
True...
Old Jan 23, 2009 | 09:19 PM
  #1609
infinus's Avatar
Tim did you ever get a chance to look at those charts I sent you? Everything look ok?
Old Jan 23, 2009 | 09:21 PM
  #1610
ttrank's Avatar
Grocery getter
Got home a midnight last night so no. I just downloaded one and will look at them soon.
If your car is not detonating you are fine to drive for now.
Old Jan 23, 2009 | 09:26 PM
  #1611
infinus's Avatar
They are all labeled at the top, my main concern was the 91 vs the stock map, i also threw in the 93 one. Also it shows my throttle slowly closing, im hoping I can get some cipher logs tonight.
Old Jan 23, 2009 | 11:41 PM
  #1612
OCG35's Avatar
do you ever track the car? Particularly 1/4 mile?... I need to shave .003 off my 1/4 mile time to get into 13s (might not sound like much, but no other VQ that I am aware of has done it on our track)... So I'm a bit leery about adding too much rotational mass...
If you do drag race - do you have ETs before and after the Akebonos?
*Side note – the rotors I have now are lightweight and are great for drag racing – problem is, I have found a passion for road course, which is why I need better brakes… word to those modding for track: choose drag or road course for your decision making mods = its very difficult to have a viable setup for both (but I’m trying)
Old Jan 24, 2009 | 12:05 AM
  #1613
infinus's Avatar
Don't have any before / after numbers. I'm not much of a 1/4 mile guy, the best I've gotten so far out of my car was a DA corrected: 14.397 @ 97.416 MPH that was pre brakes/reflash with a full tank of 91 gas and spare and everything.
The guy I got my brakes from sent out some rotors and hopefully within a month or so should have some 2 piece slotted/drilled ones that should help. Also with the 370z using the same brakes I wouldn't think that lighter rotors should be too far off.
Old Jan 24, 2009 | 12:14 AM
  #1614
OCG35's Avatar
Thumbs up
??? Does this mean you arent currently using the G37/370Z rotors?... also, does this mean there are 2-piece rotors already in development for the OEM Akebono?...
Old Jan 24, 2009 | 12:16 AM
  #1615
OCG35's Avatar
Timah - thanks for hosting the sedan clan off topic forum... TT to Mirrors to OEM BBK
Old Jan 24, 2009 | 12:23 AM
  #1616
infinus's Avatar
I am using the oem g37/370z rotors, he sent out another set for measurements to be made and I'm hoping they will be made soon so I can swap, however I have no definite eta for when they should be done but as soon as I hear anything I can let you know, I know a lot of G37's are waiting on these.
Old Jan 24, 2009 | 04:25 AM
  #1617
OCG35's Avatar
G37s????? Phhhssshhhh... I'll bet more 35s order these once viable
Thanks for the info - please keep us posted.
BTW - your in the "right" thread {pulse on viable}
Old Jan 24, 2009 | 04:42 PM
  #1618
ttrank's Avatar
Grocery getter
Mike, these will slow down your 1/4 a little for sure. Unfortunately you are going to have to pick one or the other.
Old Jan 24, 2009 | 04:46 PM
  #1619
infinus's Avatar
Fill your car with helium balloons to offset the weight.
or ditch the passenger seat/spare/tools/rear seats
or the anorexia route
not sure which of those is least appealing.
Old Jan 24, 2009 | 06:10 PM
  #1620
ttrank's Avatar
Grocery getter
Next time we go to the drags I am going to strip everything except my amp rack out of my car and see if that helps.
