Skyline Sedan
Skyline Sedan
From this URL
What is the CVT-M8 for 3k yen more than the 6MT or 5AT?
'03 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS or Vote at Online Showoff
Re: Skyline Sedan
it is a CVT transmission with 8 factory preset "gears"...
it is the top of the line sedan model in japan....
when u put this transmission in tiptronic mode, u can use two paddles behind the steering wheel, a la 360 F1, to navigate through the eight presets.....
Re: Skyline Sedan
I believe the 276hp is in Japanese measurement, not SAE measurement that we usually use here in the states...
kind of like how Bimmers and Mercs usually have DIN hps instead of SAE hps... for example, the new Bucatti Veyron has 1000 hp according to DIN standard, but "only" 987 hp when using SAE standard....
Re: Skyline Sedan
Don't the Japanese measure power in Ps or PS (whatever that means)? Someone posted the conversion factor was around .98 hp which tends to support lilteyang's comment.
Does anyone know what Ps (PS) means? Or if the conversion factor of .98 or .987 is correct?
Re: Skyline Sedan
DaveO
PS in German is Pferde Stark which means Horse Power translated. Europeans tend to measure horse power the correct way...At the wheels. So there is no exact mathmatical formula between HP at the crank and at the wheels. Let me know if I am wrong. kW is the other measurement used.
1 kiloWatt (kW) = 0.7470 BHP
Here is where I got my numbers from:
www.steve.ukmail.org/car/dynofaq.html
Re: Skyline Sedan
Check it out:
Re: Skyline Sedan
Yes, but on a CVT, they're kinda gimmicky. You get the best performance out of a CVT by just sticking it in D and letting it do it's thing. If you put it in manual mode and play with the gears, the engine gets out of it's powerband. The whole advantage of the CVT is the continuously variable gearing.
