Need Help...Will the 19" OEM Coupe wheels fit
Old Jan 4, 2007 | 02:12 PM
BadBoy06's Avatar
the 2005 sedan? I'm looking to sell my 06 wheels to a sedan owner.
Thanks!
Old Jan 4, 2007 | 02:14 PM
az1anbeethoven's Avatar
do a search...so many people have it on their sedans...it will fit...
Old Jan 4, 2007 | 02:15 PM
da mayor's Avatar
how much you want for them? any curb rash?
they won't work on a G35x b/c it's staggered unless he buys your 2 front and buys another 2 front wheels to have it match in rim and tire size
Old Jan 4, 2007 | 02:37 PM
BadBoy06's Avatar
SUPER mint 3800 miles on the meat. $1k without sensors. Guy should be picking them up tonight?
Old Jan 4, 2007 | 04:42 PM
ttrank's Avatar
Grocery getter
Yes they will fit. I believe the rears may rub a little so you may want to consider rolling the fenders if it's too bad.
Old Jan 4, 2007 | 04:51 PM
G35Papa's Avatar
Should be fine unless they lower it in the future....rears may rub ^ like Trank said.
Old Jan 4, 2007 | 05:13 PM
R2 V35's Avatar
Woookie
Old Jan 4, 2007 | 05:29 PM
BadBoy06's Avatar
Thanks!
[QUOTEShould be fine unless they lower it in the future....rears may rub ^ like Trank said.] [/QUOTE]
He said he was stock/sport set up and was fine with it. But I'll let him know.
Old Jan 4, 2007 | 06:09 PM
da mayor's Avatar
if his car is AWD then he can't throw them on. good luck on it
Old Jan 4, 2007 | 07:41 PM
Jeff92se's Avatar
Red Card Crew
Might work if he uses all the same tire size. ie.. maybe a 235-40-19?
Old Jan 4, 2007 | 08:15 PM
da mayor's Avatar
no bc the front is 19x8 and the rear is 19x8.5
Old Jan 5, 2007 | 01:24 AM
Jeff92se's Avatar
Red Card Crew
I think a 235 is okay for both a 8" and a 8.5" wheel. A 235-40-19 is what many sedan owners go to when trying to get the oem tire size and to avoid rubbing with the 245. (for the rear). I know a 235 is okay for a 8" wheel
Old Jan 7, 2007 | 03:42 PM
da mayor's Avatar
but if you have an X you have to keep the same weight and having a 19x8 and 19x8.5 wheel will not do it. i'm sure you dont put a size 12 shoe and a 12 1/2 shoe on the other leg do you?
Old Jan 7, 2007 | 04:01 PM
Jeff92se's Avatar
Red Card Crew
Same weight? I never heard of that. Can you explain on that for me? I thought you must keep the same outside tire diameter so the speed sensors won't see a differential and start activating the various awd nannies?
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
teamghost
Jul 28, 2015 04:52 PM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
