Will not start
Old Jan 7, 2007 | 08:17 PM
jcs1957's Avatar
Problems with Battety
My 2003 sedan will not start. . . again. I replaced the battery for a 3rd time (at dealer's suggestion) 3 months ago. I've also replaced the circuit board twice. When I came back from a 10 day vacation, my car wouldn't start. When I turned the key, I got no lights at all on the dash. The car was completely dead. It required a jump to start. This is a repeated problem, and has happened to me before after the car hasn't been used for a few days. Any suggestions?
Old Jan 7, 2007 | 09:31 PM
sliderg35's Avatar
It could be that all of your charging system is peachy. Your problem may be excessing drain from a problem with the security system or a short circuit from a grounding fault. Measure the current/drain from your battery when the car is off. Compare that to a G that is functioning properly. That should start you off in the right direction. Then you can start pulling fuses with the car off to figure out when the drain stops- then follow the wires...
Old Jan 7, 2007 | 10:59 PM
Andy77's Avatar
It sounds like a parasitic drain, as he said above. If it were a poor alternator, you should be seeing the alternator ("battery") light coming on.
Old Jan 7, 2007 | 11:41 PM
RocketG35's Avatar
Why do I bother to DIY???
+1 - was thinking your alternator is bad too...if its bad, it won't be able to charge the battery properly.
magnetism80
Feb 1, 2019 10:00 AM
Rhinos7777
Sep 6, 2015 05:36 PM
Jnm07
Sep 5, 2015 01:16 AM
Gwhut?
Sep 4, 2015 11:10 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
