Holy Sh*t
Old Jan 8, 2007 | 05:12 PM
jovo517's Avatar
Holy Sh*t
hey guys 2 day i was driving and i herd this squeeking noise only when i was on the gas so i checked my lugs and one was loose so when i got home i went to tighten them i saw that there was 1 lug missing in the rear i was pissed so then i go to the pass side and there was three missing they ripped out the stud. i have the m45 sport wheels with 10mm spacer and i didnt change the studs does anyone no wat i sould do and what size studs i sould get? cost?ect
Old Jan 8, 2007 | 05:30 PM
Andy77's Avatar
Holy cow! That is unfortunately very interesting and potentially very dangerous. How long had they been like this do you think? Were they improperly tightened by the shop? Good luck!!!
Old Jan 8, 2007 | 05:34 PM
Graphite05G's Avatar
The RV Specialist
Nismo 65mm studs...with spacers you only have like 2-3 threads holding on the wheel. Your lucky
Old Jan 8, 2007 | 05:36 PM
The RV Specialist
At least those are the studs that I used @$60, i think. I'm sure there are cheaper ones. Justin over at everythingg35.com gotem for me.
Old Jan 8, 2007 | 05:38 PM
jovo517's Avatar
infiniti tightened them for me so wat size studs should i buy
Old Jan 8, 2007 | 06:13 PM
ttrank's Avatar
Grocery getter
Wow!! Good thing you found out that way and not the hard way.
Old Jan 8, 2007 | 06:20 PM
The RV Specialist
They come in 55 and 65mm i went with the 65.
Old Jan 8, 2007 | 06:22 PM
gqraverice's Avatar
maybe someone was in the process of trying to steal your wheels?
Old Jan 8, 2007 | 06:27 PM
The RV Specialist
^+1 didnt think about that...the missing lug, was it stripped off or was it turned?
Old Jan 8, 2007 | 06:40 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
No... not enough threads engaged to keep them on.
You should have 9 full turns of thread engaged.
Old Jan 8, 2007 | 08:14 PM
VQ Hotness's Avatar
Same thing happend to me when i put 5mm spacers, but only my wheel started to shake and when i check sure enough i was mising 3 lugs and one came off by hand. I dont know how in the world you did it with 10mm spacers! The longer studs should of come with the kit.. Thats kinda weird.
Old Jan 9, 2007 | 03:41 PM
jovo517's Avatar
they were stripped but infiniti is tellin me that i should put the oem wheels back on without the spacer cause its not sitting right but wat size stud did u use and where did you get it from
Old Jan 9, 2007 | 03:57 PM
bert039's Avatar
Just get spacers that come with studs.
I have 15mm Project Kics on mine and the studs were already pressed into the spacer.
There's a forum sponsor, Ichiba, that also makes hubcentric spacers that come with studs:
https://g35driver.com/forums/wheels-tires-vendor/133025-ichiba-usa-aluminum-wheel-spacers-5mm-10mm-15mm-20mm-25mm-stock-now.html
paranormal
Jun 20, 2005 04:05 PM
lookin2buy35x
Jun 18, 2005 07:34 AM
mcml3693
Mar 5, 2005 10:39 PM
