Get fit!!!
Old Jan 17, 2007 | 07:07 PM
wilboytsk's Avatar
Get fit!!!
j/k...this is another damn fitment question
Can someone drop some knowledge on these specs fitting my ride:
2003 G35 sedan...on h-techs...
Wheels/tires:
19X8.5 +35 front and 19X9.5 +35 rear with 235/35ZR19 275/30ZR19 tires
Please tell me they fit
Old Jan 17, 2007 | 07:09 PM
gsRt5's Avatar
^+1............me too but on a 06, should be the same though..
Old Jan 17, 2007 | 07:16 PM
az1anbeethoven's Avatar
there have been countless threads on it...you will need to roll your rear fenders...end of story
Old Jan 17, 2007 | 07:55 PM
Chico's Avatar
Wheels/tires:
the front wheels are fine but use 245/35/19 instead. The rear tires are fine, but the offset is too low. Short answer they won't fit.
Old Jan 17, 2007 | 08:03 PM
SFG356MT's Avatar
^+1 you need to recheck the offset for the rear wheel
Old Jan 17, 2007 | 08:05 PM
wilboytsk's Avatar
Chico,
What is the rear fenders were rolled...would they fit? or they won't fit period because of the offset..which is 35.
Old Jan 17, 2007 | 08:13 PM
sunghochang77's Avatar
offset for front is 38 and the rear is 43. any number lower is no good. At 35, I don't think even rolling fenders will stop rubbing.
Old Jan 17, 2007 | 08:37 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
They'll fit, but the rear wheels will stick out of the fenders a little bit. Since you're only dropped on the H-techs, it wont rub unless your taking a hard turn. I just dont know how good it'll look with the low offset. People have used this setup before, but it's not recommended for perfect fitment.
-GP-
Old Jan 17, 2007 | 08:47 PM
wilboytsk's Avatar
-GP-
Thanks Gdup'd and to everyone else on this board...I"m getting a crazy deal on these wheels that I don't want to pass up..(unless they won't fit)..I'll try em on this wknd hoping they'll fit knowing that they probably wont..
They're off a 350z...anyone have pics of this setup on their ride....
Old Jan 17, 2007 | 10:00 PM
sliderg35's Avatar
You need +45 at least on the rear to fit a 9.5" wheel. (+48 would be better)
Old Jan 17, 2007 | 10:22 PM
G35Papa's Avatar
Don't do it. You won't wind up liking the look of the rim being beyond the fender in the rear. The front is fine with 245/35. You can dial in some negative camber if you do a drop but that is not recommended.
Just my opinion.
Old Jan 18, 2007 | 02:07 AM
(>")> G35's Avatar
http://www.sevaswheels.com/gallery/v...edan-S22-Black
That is a 20x10 +40, compared to a 19x9.5 +35, the 9.5 +35 will tuck in 1mm more than that the 10" +40, basically, it will look like in the pics...
Old Jan 19, 2007 | 12:46 AM
wilboytsk's Avatar
thanks for the pics..i decided to pass em up...thanks again for all the input fellas!!!
Old Jan 19, 2007 | 12:51 AM
ttrank's Avatar
Grocery getter
Not if you roll them.
Old Jan 19, 2007 | 12:52 AM
ttrank's Avatar
Grocery getter
It depends on the drop. Mine don't look like that at all. Mine tuck.
