Greddy TT setup
Old Jan 23, 2007 | 04:22 PM
Floyds_racing's Avatar
Angry Greddy TT setup
I was just told that I shouldnt put a TT kit on my car because its an Auto and that the tranny cant handle it? Is there a way to rebuild the factory tranny and beef it up?
Tyson
Old Jan 23, 2007 | 04:31 PM
g35sedan5at's Avatar
the same tranny is used in the QX so i think it can handle it...the only thing is the rpm's will go up too fast for the tranny to shift. you should probably get a stillen valve body upgrade. see what others have to say before u take my advice,lol
Old Jan 23, 2007 | 04:35 PM
ttrank's Avatar
Grocery getter
Do a valve body upgrade and you should be good up to ~***-***whp. Ask Tinman, he has had an SFR TT kit on his 5AT for some time.
Edit: looks like they hold up to ~550whp. There is a link a few posts down.
Old Jan 23, 2007 | 04:38 PM
Neal376's Avatar
yea VB upgrade. purchase and instal usually sets you back a grand. for some reason...maxima and altima vb upgrades are much cheaper
Old Jan 23, 2007 | 05:19 PM
devster's Avatar
I am sure the FWD vs RWD transmission has something to do with it.
Old Jan 23, 2007 | 05:29 PM
zackt69's Avatar
rarejdm.com
http://sgpracing-store.stores.yahoo....raupvabof.html
Old Jan 23, 2007 | 05:51 PM
a have a quesiton of my own....after 450 wrhp what can one do to upgrade the auto tranny????
Old Jan 23, 2007 | 05:54 PM
Graphite05G's Avatar
The RV Specialist
SGP's upgrade is holding 650+---cant ask for more than that
Old Jan 23, 2007 | 06:48 PM
ttrank's Avatar
Grocery getter
It says 550, not 650.
They also talk about a full custom tranny that will go into the 850 range. Check out the link.
well graphite....i do believe there is a shop (name escapes me) that has a dialr driver G35 coupe at 700+ hp......i know its a manual but how is this obtainable with an auto??? if it even is obtainable...lol
Old Jan 23, 2007 | 06:53 PM
ttrank's Avatar
Grocery getter
VRT has their coupe which makes 760whp/800wtq. I met a guy here in Phoenix who has ridden in it and he said you can't even tell until you hit the gas. It's quite a sleeper for the most part.
It's the same engine so with the right TT set-up you can make similar power with an AT.
Old Jan 23, 2007 | 07:30 PM
760/800!!!!!!!!!!!!!!!!!! holy ****!......speachless
Old Jan 23, 2007 | 08:01 PM
G-Mony's Avatar
it's all about the tune...
but if u plan on going F1 just keep in mind that u might blow your tranny. i wouldnt build it till u break it. only thing i did was tranny cooler...didnt like choices for VB
Old Jan 23, 2007 | 08:28 PM
ttrank's Avatar
Grocery getter
So you didn't do a VB upgrade? I guess since you are still down in the 400 range you are ok. Good call with the cooler.
Old Jan 23, 2007 | 11:04 PM
VQ Hotness's Avatar
Thumbs up
I don't think are cars would stand a chance in the Formula One circuit
If it ain't broken why fix it.
How much of a hassle would it be to convert to 6mt? I couldnt see it costing to much.
