OE Tire mileage
Old Jan 24, 2007 | 05:29 PM
infini_'s Avatar
OE Tire mileage
Guys... i know a lot depends on how you drive.... but how much you got out of the original tires that came with the G. I have 26k on my 2005 and i think i can squeze another 5-6k miles out of them.
Old Jan 24, 2007 | 05:38 PM
krishlad81's Avatar
wow - i am at 3700 miles and I am noticing some good tire wear - especially on the edges. I guess I need to slow it down on the corners. I wonder when i rotate my tires - if I should cross rotate them so that the sidewalls/edges have even wear on both sides on the fronts especially.
Old Jan 24, 2007 | 06:09 PM
G35Luv's Avatar
On the Stock 17" wheels/tires. I took them off at 36k and there was still 2mm before the treadwear indicators. So I gather they could go 40k... I guess it does depend on how you drive and how you maintain your tires air pressure.
Old Jan 24, 2007 | 06:12 PM
bythabay's Avatar
32k on my original Goodyear Eagle NCT 5 tires. I'm going to TRY to keep them on 'till 45k and then get new ones
Old Jan 24, 2007 | 06:18 PM
g35sedan5at's Avatar
damn! i got 7500 miles on my nct-5 and theyre gona have to be changed within 10k mark...i guess the first month of peeling out has come to haunt me
Old Jan 24, 2007 | 06:26 PM
bythabay's Avatar
don't get me wrong, I take corners hard and I don't go easy on the throttle. I just make sure I keep 'em rotated properly every time I change the oil :P
Also, another thing to keep in mind is you can affect how the tires wear better by adjusting tire pressure. So say after a bunch of cornering your sides are worn, you can increase the pressure to wear the inside of the tire more, that way you can balance it out better and the tires will last longer even with harder cornering.
Old Jan 24, 2007 | 06:53 PM
naw....my problem is peeling out for the first month..i have 3k or less left on my rears for sure...and i only have 7500 miles!!!
Old Jan 24, 2007 | 07:40 PM
SFG356MT's Avatar
Goodyear @ 22K then I went with some 18's. The rear tires were just short of the wear indicator and the front was just slightly better.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
j_mullet
Aug 26, 2015 10:49 PM
Gip
Aug 24, 2015 05:31 PM
JoeMac
Aug 20, 2015 10:17 AM
TheefrshstVQ
Jul 26, 2015 09:37 PM
