G35 h-techs for non-sport G sedan
Old Jan 27, 2007 | 03:42 PM
rzaid's Avatar
To anyone who may know:
1. Do g35 tein h-techs provide a different drop for G sedans w/out sport suspension vs. sedans with sport suspension? If so, how much?
2. What is the difference in ride quality compared to oem non-sport springs? (stiffer, same, softer)
3. Will h-techs cause non-sport shocks to wear out prematurely?
4. Can one put 350z h-techs on a non-sport G sedan? If so, what kind of drop and difference in ride quality?
Thanks
Old Jan 27, 2007 | 06:24 PM
ttrank's Avatar
Grocery getter
Sport vs. non-sport does not matter unless you plan to keep the struts which I would not do anyway.
Old Jan 27, 2007 | 08:05 PM
woshiagni's Avatar
Not sure about #1 and #4 but if you are asking about the sedan H-techs:
2. Ride quality is about the same as the Sport springs, maybe a little softer. Check the spring rates on the springs/shocks sticky.
3. Your stock shocks will probably be fine for a long time with the sedan H-techs, it's a very mild drop (IIRC 1" in the front and 0.75" in the back). The spring rates are also very similar between stock and H-techs.
Old Jan 27, 2007 | 08:53 PM
Nismo G's Avatar
If you are looking for g35 h-techs.... I still have a new set in the box in my garage. Im getting coilovers insted so let me know 110 shipped!
To answer a couple of you questions. Yes it will prove about a .75 inch drop on the sedan. The sports suspension and the regular suspension have the same ride heights. With the h-tech you will have the same handeling as the sports tuned suspension with a more aggresive look.
-sean
Old Jan 27, 2007 | 09:41 PM
rzaid's Avatar
Cool guys thanks. No thanks for the springs Nismo. I'm not in the market as of yet. Probably in a year or 2.
Does anybody know the actual oem spring rates for a non-sport G sedan?...so I can compare to the h-techs
Old Jan 27, 2007 | 09:45 PM
Nismo G's Avatar
Oem rates G35 Coupe/350Z: 314front/342rear
Oem rates G35 Sedan w/sport: 314front/342rear
Oem rates G35 Sedan non-sport: 280front/315rear
Tein H-tech for G35 Coupe (SKP30-BUB00)
F/R Progressive - spring rates listed rates are final rates
324front/260rear
(vs stock G35 Coupe) F+5% R-22%
Transfers: +27% spring rate balance to front
F drop –0.6”
R drop –0.3”
-sean
Old Jan 27, 2007 | 10:03 PM
rzaid's Avatar
dude that was a fast response
is it me or is it weird that the rear h-techs are softer than non-sport rears?
hey nismo, do you have any experience with the h-tech ride quality?
should i just get front h-techs and leave my stock rear?
Old Jan 27, 2007 | 10:05 PM
Nismo G's Avatar
I dont have any experience. I baught the springs and never installed them so i couldnt tell you...i would just search around the forum.
-sean
Old Jan 27, 2007 | 10:07 PM
Mmagic76's Avatar
Old Jan 27, 2007 | 10:14 PM
rzaid's Avatar
cool...thanks for the help
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
Popes
Jul 29, 2015 05:07 PM
teamghost
Jul 28, 2015 04:52 PM
laksjd84
Jul 24, 2015 05:12 PM
