Baby seat...how are the leather seats holding up?
Old Mar 15, 2007 | 12:19 AM
  #46
mikeee2's Avatar
Ok...I finally had the time to set up the baby seat (baby due any day now). I kinda forgot about the replies from this thread (sorry...short term memory) so I went ahead and setup the baby seat in the center taking the two middle latch. From previous post, some said the latches are design for the side seats and also someone replied that they do use the two center latches.
Sorry for the crappy phone camera pictures...
So should I used the seat belt method? Isn't the seat beats always in the way when you put the baby in and out? Also, I do not think the baby seat comes with anything to strap to the tether (the metal clip behind the head rest).
Anyway, now with the baby seat on the two middle latches, it kinda slide left and right and definitely more than an inch. Am I doing it wrong?
Old Mar 15, 2007 | 01:22 AM
  #47
RocketG35's Avatar
Why do I bother to DIY???
As I said, the middle latches aren't meant for use in the middle seat. Read the manual.
I had the same problem you had...the baby seat slid sideways. The police inspector said to twist seat belt button end a couple of times to reduce the slack. The center seat has a really long button end! This helped a lot. Also, make sure you get some of the grippy shelf liner. The police inspector said that will help reduce the sliding...and it does.
My rear facing seat didn't have a tether for the top clip...sorry, I kept thinking forward facing! I had a Peg Perego and once I reduced some of the sliding (can not eliminate it entirely), it seemed fine.
Make sure you take it to an inspector. Police stations or baby stores can check them either through open days or scheduled appts. Check this approved list...
http://www.nhtsa.dot.gov/people/inju...inspection.htm
Old Mar 15, 2007 | 07:28 AM
  #48
mikeee2's Avatar
Thanks. I'll try it again tonight securing it in the center but with the lap/shoulder belt. Just seem very clumsy with the belt wrapping on top of the baby seat. Maybe I should consider using the latches and place the seat on the side?
Old Mar 15, 2007 | 07:32 AM
  #49
jimmyc13's Avatar
For a camera phone, those pictures came out great IMO!
When I install my car seats in the rear, I use my own weight on the car seat (put my knee on the base and/or seat) and then pull the tension as tight as possible. This will help reduce the sliding as well.
Old Mar 15, 2007 | 07:38 AM
  #50
RCMCFE's Avatar
If you're not sure, take it to your nearest Fire dept. or highway patrol station. They'll install it for you and show you how to do it properly.
Congrats.
Old Mar 15, 2007 | 09:07 AM
  #51
mikeee2's Avatar
Haha...I have a Sony K800 phone. It does say it's a 3.2 megapixel camera but of course it's no where close to the quality of an actualy 3.2 mp. Anyway, so how are you securing it? Center? Side? Using latch? Seatbelt?
Old Mar 15, 2007 | 09:33 AM
  #52
darnelled's Avatar
I would definately go with some sort of seat protection- even if it's just towels. I cleaned up my interior last night and removed my 2 1/2 yo son's seat to finish the job. I usually remove the seat when not in use, but he is only in it about once a week and there is some stretching of the leather under the seat. I used some leather cleaner, then conditioner all over and just hope it tightens back up.
Old Mar 15, 2007 | 09:53 AM
  #53
omasica's Avatar
What I do is put a towel under the baby seat so it doesnt rip or crack the leather
Old Mar 15, 2007 | 10:00 AM
  #54
Swivel's Avatar
Moderator
Originally Posted by GEE35X
Yes they are in Canada Bobby, heck not long now for the arrival of your Daughter. Must be excited.
Shane they are part of Toys r us.
Here is the Canadian website : http://www.toysrus.ca/webapp/wcs/sto...langId=-1&N=27
Here is that seat Protector: http://www.toysrus.ca/webapp/wcs/sto...9835&nvalue=24
Glad you guys found and posted these, I noticed them in a flyer not long ago and intend to pick some up this weekend. Funny how when kids come along, our definition of 'mods' shifts a bit...
Old Mar 15, 2007 | 12:21 PM
  #55
jimmyc13's Avatar
Well now that I have 2 kids (as of last October), I have one on each side. I never did the center seat thing...way too difficult loading the kid in & out each & every day @ daycare. I am using the latch....it's WAY tighter w/ that install method than with a seatbelt.
Old Mar 15, 2007 | 02:06 PM
  #56
Xer's Avatar
Xer
My solution for the twins was easy, I bought wifey an Armada, this keeps the G clean. I can put the 2 seats in the back although it is tight, I have done this a couple of times only for a couple hours and they left a impression for some time afterward. I to use the knee on base method and reef down on the strap(tether) believe me when I am done, these seats do not move, gotta keep my future G men safe!!!!!
Old Mar 15, 2007 | 02:11 PM
  #57
Jeff92se's Avatar
Red Card Crew
I used this when my daughter was in rear facing:
http://www.toysrus.com/sm-mighty-tit...i-2267437.html
This beats kneeling down on the base and pulling on the seatbelt. Gets it as tight as you want.
Old Mar 15, 2007 | 03:50 PM
  #58
tkman00's Avatar
i made the mistake of putting my kid in the center after he was born using the latch. As others have said it allows alot of play from side to side. i've also done rear facing convertible in the middle and finally forward facing on the side. LATCH on the side is definitely the way to go. And when it's on there tight, you can actually shake the car when testing for any play. I'm expecting number 2 in a few months and will probably put the carrier on the side since the middle might be somewhat tight.
Old Mar 15, 2007 | 04:12 PM
  #59
mikeee2's Avatar
Hmm...interesting. Maybe I'll just use LATCh on the side then. Now the question is which side? I guess diagonally from me. Since if I would to put baby seat behind me then I won't be able to push back my seat much.
Old Mar 15, 2007 | 05:14 PM
  #60
tkman00's Avatar
passenger. rationale is that if you need to reach back there quickly, it's easier.
