camber kit
Old Feb 2, 2007 | 04:27 AM
kenasaki's Avatar
camber kit
hey guys, as some of you may know i just stuck wheels on my ride and lowered it. now, i need a rear camber kit. just wondering if you guys had any ideas of good camber kits and where to order them from? i looked on everythingg35.com and i only saw the stillen kit for 350z & g35 coupes. is there a difference? i need one soon. but still need to get an alignment checked.
Old Feb 2, 2007 | 04:33 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
SPC rear camber arms and toe bolts. I have em and i'm lowered the same as you in the rear. I was able to bring my rear camber from -2.2/2.3 to -1.6/1.7 with the kit, and on both sides the toe is around 0.10
$200 new from some of the vendors here on our site.
-GP-
Old Feb 2, 2007 | 08:19 AM
ORANGEBSRT's Avatar
you might need a toe kit. my camber with the H-techs are about -1.2 all around but my toe was seriously affected. Check on Performance Nissan for the kits. That where I have to order my rear toe kit.
Old Feb 2, 2007 | 09:05 AM
Mmagic76's Avatar
I understand Camber being affected, however the toe being so bad that you need a toe kit? I was thinking of installing the 350z springs, however, after hearing this, I might not! I don't want to spend more $ on a toe kit.
Old Feb 2, 2007 | 11:49 AM
jimmykce1's Avatar
I installed coupe springs in the rear and 350z springs in the front. The rear wheels were within stock specs; however, the front wheels camber were off a little. I ended up getting SPL front camber kit installed to bring them back into stock specifications.
Old Feb 2, 2007 | 12:25 PM
ttrank's Avatar
Grocery getter
I would get the SPC kit. They are a good name with many years behind them. Also the kits are a good deal. There is a vendor with a sale on them around here somewhere.
Old Feb 2, 2007 | 12:49 PM
MaidenG35's Avatar
I got my SPC rear camber kit with toe bolts from Import Auto Performance. I believe they are one of the sponsors here so look up their name it is IAPDirect.com..they might be having some good deals. Also check out thmotorsports..they're all under the marketplace section..I see you live in Socal so once you get them, take your car into West End in Gardena for install/alignment..The guy's name is Darrin..his number is 310-808-9233. He only works by appointments and if you do make an appointment, don't be late.
Old Feb 2, 2007 | 12:59 PM
jimmyc13's Avatar
Wow...for real? I thought I did all my homework & just purchased the same springs for the front & rear..thought I'd be within spec.... How much does this front kit cost? Do I truly need it? If I rotate fronts to back every 5-7K miles, wouldn't I be okay?
Old Feb 2, 2007 | 01:30 PM
I had revised Z springs on my car, they drop it more than h-techs and i easily brought my car back into specs with the factory eccentrics. I dont know what he's talking about.
-GP-
Old Feb 2, 2007 | 01:32 PM
i wouldnt worry about the front camber too much, its only slightly out of spec with that setup. If you rotate the tires, you'll be fine.
-GP-
Old Feb 2, 2007 | 03:02 PM
ORANGEBSRT's Avatar
-GP-
So your tellin me your toe is still within spec and your lower than H-techs?
Old Feb 2, 2007 | 04:48 PM
jimmyc13's Avatar
-GP-
Cool..that's what I thought..I will be rotating, so shouldn't be a big issue then.
Thanks!
Old Feb 2, 2007 | 09:39 PM
StarChamp's Avatar
Don't ignore your rear toe alignment aftering lowering. This pic shows what the combination of added negative camber and severe rear toe-out will do to a set of tires after about 5k miles. It was my own fault for not even checking the toe after installing my Eibachs. I used Kinetix fully adjustable camber and toe arms to correct the problem. Front camber and toe was easily corrected with factory hardware.
Old Feb 2, 2007 | 09:47 PM
jimmyc13's Avatar
^^^WOAH! That's after only 5k miles!?
Old Feb 2, 2007 | 10:09 PM
StarChamp's Avatar
I tend to be a little heavy on the gas
