Another rim ?
Old Feb 13, 2007 | 06:25 AM
BuckeyeG's Avatar
Originally Posted by perry05G35
^There's a lot of choices you can go with since all the wheels are 18X8 you can go with 225/45/18 front and 245/45/18 rear which won't affect your speedo but you can also play with the a lower profile which would probably be cheaper 225/40/18 and 245/40/18 you will be out of spec but it will give you more play when you go to lower your car on unrevised 350z springs at all 4 corners. The 350z springs in the rear would be lower than having G35 coupe springs and with your +40 offset the lower profile tire in the rear shouldn't rub.
What do you mean I will be out of spec? My speedo?
Old Feb 13, 2007 | 04:00 PM
perry05G35's Avatar
^ Your tire circumference will be less than the factory tire circumference so your speedometer will be out of spec it's not uncommon and not that drastic.
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
