VDC + Burning Rubber smell
Old Feb 15, 2007 | 07:40 PM
  #32
Xman's Avatar
I had my heat set at 64 degrees. When I put it down to 62 I don't smell it.
Old Feb 15, 2007 | 09:39 PM
  #33
53G35's Avatar
I've smelled this, too. I attributed it to the fact that I was wearing boots with rubber soles for snow and the hot air blowing on them created the odor(???)
Old Feb 15, 2007 | 09:42 PM
  #34
kvangil's Avatar
Sometimes, I can smell it outside the car, towards the front, when I'm parked in the garage...
Old Feb 16, 2007 | 08:29 AM
  #35
whiterhino529's Avatar
lsd
Originally Posted by Potty_Pants
any chance it could be the LSD ?
you talking about these guys tripping on lsd?
Old Feb 16, 2007 | 09:17 AM
  #36
IllQueensG35X's Avatar
I've noticed the smell as well. It smells like rubber so I assumed it was my break fluid. I did notice the smell when my VDC kicks or after I use the snow mode. If something is evaporating, I hope we find it b/c the fluid will eventually be empty and we will all will have more misfortune's ahead...
Old Feb 16, 2007 | 10:59 AM
  #37
infini_'s Avatar
I smell the same odor.... there is one way to find out for sure if its your brakes.... pull the e-brakes and drive your car for 3-4 miles.... if you smell the same odor... then its your brakes.... otherwise its something else.
Old Feb 16, 2007 | 12:25 PM
  #38
kvangil's Avatar
I doubt that would give you any answers--all it'll do is eat up your parking-brake shoes. The e-brake is a separate system from the regular brakes. There are brake shoes in the rear that holds the car when you pull the e-brake handle. It's not the rear pads holding the rotors...
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Blue Dream
Dec 5, 2015 10:56 AM
hrdwirk1
Oct 2, 2015 06:34 PM
dcsbh1
Oct 1, 2015 03:15 PM
markbilo
Sep 30, 2015 01:33 AM
