GPS- mods/hacks?
Old Feb 15, 2007 | 05:00 PM
s0nicstr1fe's Avatar
GPS- mods/hacks?
I used the search on the forum to try and see if I could find any documents on Modding your GPS
So far all I could find was information on Acura through google, and some off topic stuff about the g-Navi.
I want to be able to change the home/loading screen to something else in my navi.. anyone knows how I should go about doing with without having to rip apart *.*bin files on the dvd-rom all day?
Old Feb 20, 2007 | 04:57 PM
robr's Avatar
That would be neat, but even more useful would be a hack to disable the question you have to answer at boot and even better, allow actually having 100% use of the GPS while moving (without having to put in a physical toggle to disconnect the antenna).
I'll be watching this thread with interest (hopefully it gains some momentum ).
Old Feb 20, 2007 | 10:30 PM
sliderg35's Avatar
It's already been done...
https://g35driver.com/forums/showthr...ight=navi+hack
I've got one and it's great!
Old Feb 20, 2007 | 11:18 PM
robr's Avatar
dammit, no longer available, and the kp version people keep talking about is apparently a giant PITA to install. I can barely handle a screwdriver, nevermind taking apart most of the dashboard. Actually I could probably take it apart, getting back together would be the issue.
Old Feb 20, 2007 | 11:47 PM
KPierson's Avatar
Both modules install the exact same way. MechEE was going to buy a unit from KPtech and instead decided to build his own, modeled after ours. It has the exact same connections in the car that ours does.
There may have been some confustion because he was selling his mainly for 05+ cars which are MUCH easier to install in. The 03/04s require quite a bit of disasembly. MechEE also made light of the fact that you need to solder a wire on his directly to the circuit board (just like the KPtech). KPtechnologies wants customers to know exactly what is involved before they buy a module, so they won't be surprised.
Our newest version now offers a soft electronic beep to alert you when you bypass the VSS (allow programming while moving). It will then alert you again when the VSS is reconnected.
Old Feb 21, 2007 | 02:12 AM
garyjay's Avatar
Talking
Kevin,
Will your Nav bypass module work in an 07 G35 Sedan?
Thanks!
Gary
Old Feb 21, 2007 | 07:32 AM
robr's Avatar
Well I'm not going to even think about doing the install myself for something like this. I know what I'm good at and what I'm not, so if there is anyplace in MA/NH that is familiar with the install please let me know, otherwise I guess I'll live without or eventually see if I can figure out if there is some sort of hardware emulator and disassembler out there and modify the software itself.
Old Feb 21, 2007 | 08:38 AM
KPierson's Avatar
Originally Posted by garyjay
Kevin,
Thanks!
Gary
To my knowledge it has never been tested on an '07. From what I've been told you can accept the disclaimer through the steering wheel buttons, so it isn't as big as deal.
In order for it to work, there has to be a physical 'OK' pushbutton on the navi, and everytime you start the car it has to immediately go to the 'OK' screen.
