Dyno Results from today!!!
Old 02-21-2007 | 05:20 PM
bluestacy04's Avatar
OK guys I finally got some runs in since I added my Motordyne 5/16 spacer and changed over to Amsoil oil/filter. I went from 218hp and 228tq (looking for old dyno sheet as we speak) to 231hp and 224tq. Its a 5at by the way
Looking lean down low in the band and a little rich up top!
When is Cobb releasing the tunning deal?
Last edited by bluestacy04; 02-21-2007 at 05:26 PM. Reason: Forgot to add that its a auto
Old 02-21-2007 | 05:23 PM
Jeff92se's Avatar
Red Card Crew
nice numbers. I think your AF if fine but the other guys will comment. 6mt or auto?
Old 02-21-2007 | 05:24 PM
Auto
Old 02-21-2007 | 05:25 PM
I forgot I did make a little more power on one run but Its not a great graph since it hit overdrive.
235hp and 210tq
Old 02-21-2007 | 05:26 PM
Jeff92se's Avatar
Red Card Crew
Sorta odd that you lost torque. How exactly did you dyno? ie.. method for auto. ie.. floor it w/o it downshifting?
Old 02-21-2007 | 05:27 PM
Manumatic in 4th, didn't floor it until 3500.
Old 02-21-2007 | 05:32 PM
Jeff92se's Avatar
Red Card Crew
Cool. That seems to correlate to when the a/f goes to WOT mode. ie.. part throttle is lean (closed loop) to the open loop rich mode (about 4500rpm).
Old 02-21-2007 | 05:36 PM
chobble19's Avatar
word nice increase! i pulled 249 on a dyno jet with my mrev and 5/16...but i am 6mt. i was tol the mrev didnt help much so i think i may remove it sometime soon and get a aps or crawford plenum =)
Old 02-21-2007 | 05:38 PM
absolutg's Avatar
workin...
i thought at should dyno in 3rd? might be remembering wrong
Old 02-21-2007 | 05:42 PM
chobble19's Avatar
mine was done in 5th....
Old 02-21-2007 | 06:35 PM
Floyds_racing's Avatar
Nice I wish I could find the time to take mine!
Old 02-21-2007 | 06:55 PM
I did do a run in third today for the heck of it and the pull was almost the same at the 231hp one, but with some more tq.
Old 02-21-2007 | 07:04 PM
godmans's Avatar
Good numbers for a 5AT on a dynojet
Old 02-21-2007 | 08:16 PM
seddon's Avatar
Pretty good numbers what year is your G.
Old 02-21-2007 | 08:54 PM
ttrank's Avatar
Grocery getter
Most AT guys use 4th and the MT's use 5th.
Quick Reply: Dyno Results from today!!!
