Help removing console
Old Mar 1, 2007 | 03:34 PM
NonAme's Avatar
ANyone know how to remove the wood panels? i want to get a look inside the gear shift n stuff. I wana see wtf is rattleing in there. Everytime i break medium-hard i hear creaking noise. Like two plastic rubbing agianst each other. Also when i accelerate fast like when the car jerk forward, the dash sounds like plastic cracking.
I hoping i could cushen it somehow with cushon tape or something if i could look inside and see what is going on.
anyhelp is very much appreciated.
Attached Thumbnails Help removing console-image_153.jpg   Help removing console-image_154.jpg   Help removing console-image_155.jpg
Old Mar 1, 2007 | 09:04 PM
ttrank's Avatar
Grocery getter
If I remember right you just lift up on the bottom, it snaps into place. It has been a good year since I worked on an 06.
Old Mar 1, 2007 | 10:21 PM
jameyb's Avatar
Should be the same as the aluminum trim. See this DIY:
https://g35driver.com/forums/audio-video-electronics/99632-pac-aai-nis2-ipod-adapter-installation-guide-05-dash-removal.html
It is what I used when I installed my USA-Spec.
Old Mar 1, 2007 | 10:57 PM
NonAme's Avatar
WOw thanks
now that i have this guide, ima try forsure.
ill either f%^k things up worst or finally get this clicking resolve.
thanks again.
Old Mar 1, 2007 | 11:04 PM
jameyb's Avatar
Before you tear into it, be sure to get some felt with tape on one side. I used it to eliminate some rattles in my center consol in the area it sounds like you are referring to.
Old Mar 2, 2007 | 12:03 AM
ttrank's Avatar
Grocery getter
Yeah that DIY is the same.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
