strange sound
Old Apr 1, 2007 | 06:31 PM
Mr.Igor's Avatar
strange sound
i have a strange sound coming from the front suspension, on right side. dealer said its either sway bar link or compession rod... but they couldnt tel me which one is it.
Old Apr 1, 2007 | 07:45 PM
kvangil's Avatar
I assume you're out of warranty? Anyway, grease the compression rod bushings and see if the noise goes away. If you search, you should be able to find the DIY thread on that.
Old Apr 1, 2007 | 09:04 PM
Mr.Igor's Avatar
its only on right side, it makes sounds when i go on a bumpy road with little rocks. when i push down the car from that cornor it makes like a rubbing sound kind of like its hitting something.
Old Apr 1, 2007 | 09:11 PM
KrazyEd's Avatar
I had a sound that was coming from my front suspension when I would go up/down driveways and speed bumps. I took it to the dealer and they grease the compression rods and the sound is gone!!
Old Apr 1, 2007 | 10:45 PM
kvangil's Avatar
Then that doesn't sound like compression rods...
Old Apr 1, 2007 | 10:46 PM
ttrank's Avatar
Grocery getter
What kind of rubbing sound? Like a squeak or click or ??
Old Apr 2, 2007 | 12:53 PM
Toxa's Avatar
check the bushing - it may be torn
Old Apr 2, 2007 | 02:37 PM
Mr.Igor's Avatar
more of a click sound, not like a huge rubbing sound. like KrazyEd said, when i go over speed bumps, or up and down driveways i get this sound from one side.
Old Apr 2, 2007 | 02:52 PM
Mr.Igor's Avatar
no DIY ;(
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
