MY STOCK G35 DYNO
on
MY STOCK G35 DYNO
Hey Guys... Here are my Dyno numbers from January 25th, 2003..
They seem kind of high, and I have no mods to my engine.. Check them out, give me some feed back:
Engine Modifications: None
Where? R&D Dyno Service | 115 E. Gardena Blvd. | 310.516.1003
Measured on a DYNOJET's MODEL 248C DYNAMETER
REZA.003 84.8 ^F 30.17-.027 in.Hg. 0 Ft. CF=0.98
Max POWER = 242.1 Max TORQUE = 217.7
third gear
REZA.001 84.6 ^F 30.17-.027 in.Hg. 0 Ft. CF=0.98
Max POWER = 265.5 Max TORQUE = 218.7
third gear
REZA.002 84.7 ^F 30.17-.027 in.Hg. 0 Ft. CF=0.98
Max POWER = 249.2 Max TORQUE = 220.5
third gear
I dont have any images yet.. but if its "THAT" important, I guess i can scan them... only reason why I havent is becuase im doing mid-terms right now..
..pestilence..
third gear
third gear
third gear
..pestilence..
Guest
Posts: n/a
Re: MY STOCK G35 DYNO
These number don't seem right. Because Dyno's measure rear wheel hp so if these numbers are correct and are rear wheel hp numbers then your G is pushing ~320hp... And that is only using a 20% drivetrain lost. Is this a Sedan or Coupe?
Dave
2003 G35 Platinum/Willow
Nav, Premium, Winter, Spoiler, Wood
http://www.zr1.net/g35.html
Dave
Guest
Posts: n/a
on
Yeah i have a sedan... Ill scan the dyno in (tomorrow ill try, if not next week).. I have midterms so its hard to find time to scan it.. those are the real numbers tho.. im not making them up.. i have no intrest in making them up... anyways.. ill try to get em scanned tomorrow and post it..
..pestilence..
..pestilence..
I don't think your making them up pestilence, I just think the guy who ran the dyno's for you messed up... When you run a dyno its measuring the power at the wheels... If the G35 Sedan is rated at 260 hp @ the crank then there's no way you can be getting over 260 hp @ the wheels... even the runs that got you in the high 240's @ the wheels is to high..... In the future I would definately stay away from the guy who did the dyno runs for you and find a shop with more experience...
Just for a refrence, if you get anything higher then 220 Hp @ wheels on a G35 Sedan, then somethings not right... I've seen dyno's on the coupe (rated at 280 hp @ crank) only getting in the high 230's hp @ wheels...
on
Yeah i konw what you guys mean... When he gave me the sheet i was like hmmmm... It was my first dyno run.. I couldent really understand the differences between the runs.. and why the numbers were so different. .. Can anyone recommend a good dyno place in southern california? I need to get a baseline dyno for my car so I can begin mod'ding it up.. )
..pestilence..
..pestilence..
Guest
Posts: n/a
My only thought on this is that they are giving you crank HP not rear wheel HP. They may be able to add in what they feel is the drivetrain lost of around 20%? Ask them if the numbers they gave you was rear wheel HP?
Dave
Dave
