Headlights on 2003.5 Sedan
Old May 2, 2007 | 04:56 PM
Typhoon's Avatar
Has anyone had any problems with the headlights moving, when you press on them? My driver’s side moves about 1/8" when the hood is closed, and 1" when open. (But it does not move when driving?)
The dealer wanted $893 to fix, and would not pass my vehicle inspection. What crooks!!! They claim it was not cover under warranty, but there is no way it’s loose because of someone/thing hitting it. I think whatever secured it failed.
Old May 2, 2007 | 05:34 PM
ttrank's Avatar
Grocery getter
The headlight has 4 mounting points; 1 on the outside, one on top and two on the front. Check to make sure they are all secure. They use 10mm bolts.
Old May 2, 2007 | 05:53 PM
Typhoon's Avatar
Thanks. I will check for those 4 mounting points.
BTW - My local mechanic, passed my inspection without a problem, since the ligths were not misaligned, and they worked!!!
Old May 2, 2007 | 05:56 PM
ttrank's Avatar
Grocery getter
Sounds like your dealer has some real nice guys working there.
Old May 2, 2007 | 08:08 PM
chinaman_87's Avatar
If it is one of the bolts coming loose you should sue the **** out of that dealership for telling you it'd cost 893
Old May 3, 2007 | 04:13 PM
Typhoon's Avatar
I thought they were. Now I have a totally different opinion of them!! What makes it crazy, it that they knew about it before my warranty expired on March 31, 2007!
Old May 3, 2007 | 04:14 PM
Typhoon's Avatar
I wish it was that easy!! But, they will never see me there again, unless I buy another Infiniti.
Old May 3, 2007 | 04:37 PM
ttrank's Avatar
Grocery getter
This is why I try to do all my work myself. At least that way if anything is wrong I know about it and can fix it ASAP.
Old May 3, 2007 | 04:47 PM
Typhoon's Avatar
You are so right!!
Now that it's out of warranty, I guess I will do the repairs myself from now on.
Old May 6, 2007 | 01:04 PM
bbboltz's Avatar
did you get to fix them by tighting those screws?
Old May 7, 2007 | 10:55 AM
Typhoon's Avatar
The bottom bolt hole is broken. So, I used some super strong gel Krazy glue to secure. I did it on Saturday morning, and so far it's holding up. I guess I will continue to glue it, until I spend $893 in glue!! LOL
Old May 7, 2007 | 12:39 PM
ttrank's Avatar
Grocery getter
If it is the tab that is broken you can use an "L" bracket to make a new one.
Old May 7, 2007 | 08:15 PM
bbboltz's Avatar
Old May 7, 2007 | 10:04 PM
Typhoon's Avatar
I will see how long the glue holds. If it holds for a few weeks, then I will just keep gluing. Also, I am too lazy right now to get under the car to modify the broken bracket. (I can't see it from the top.)
Old May 8, 2007 | 12:37 AM
ttrank's Avatar
Grocery getter
Good luck
Jusseth
Sep 13, 2020 12:25 PM
itgogitrev
Lights
May 2, 2016 06:53 AM
derres
Aug 28, 2015 03:27 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
andresito7
Aug 1, 2015 04:53 AM
