Ground kit + extra custom wire for tranny ecu
Old May 17, 2007 | 04:06 PM
Jeff92se's Avatar
Red Card Crew
I happened to buy another ground kit from a member here. It had the tranny case ground but not the tranny ecu ground. I have an 03 auto that has the TCM near the ECU.
So I quickly made another wire using 8 ga and some connectors. Crimped and soldered. I attached it to one of the TCM holding brackets and ran it up to the battery ground strap connector on the firewall.
There is one bolt not used (oem uses two) and my existing kit removes the oem ground strap and replaces it with thick arsed wires/connectors).
Only got one day on it but it "seems" to be shifting better. I tried to use the best ground possible so I wouldn't have to move that around to compare. In MM, it seems to get into gear faster when manual shifting. And when left alone, it seems to downshift ever so slightly sooner.
Hell, even making one wire with connectors and doing just this might be worth it.
BTW IMHO 8 ga is plenty. Especially when a typical ground is only what, 18-20ga? And there's no heat in this area anyway.
Old May 17, 2007 | 05:51 PM
SLVR JDM's Avatar
Maybe this is a stupid question, but what is the objective of the grounding kit? What positive gains are associated? Just curious, thanks.
Old May 17, 2007 | 06:49 PM
Jeff92se's Avatar
Red Card Crew
https://g35driver.com/forums/showthr...ght=ground+kit
I'm running the Caskyline kit
Old May 17, 2007 | 07:22 PM
bert039's Avatar
Do all 03's have the TCM near the ECU?
Old May 17, 2007 | 07:25 PM
Jeff92se's Avatar
Red Card Crew
I think so. I'm going to "guess" at least all G sedans until 05 do. As that's the year they got the updated TCM programming. ie.. MM auto shifts to 1st, rev matching downshifts etc.... So I assume that's the year they stuffed the TCM inside the tranny.
Old May 17, 2007 | 09:03 PM
ttrank's Avatar
Grocery getter
Yeah I agree that 8ga is plenty.
Old May 17, 2007 | 10:49 PM
OCG35's Avatar
nope, my 04.5 has it inside.
Old May 17, 2007 | 11:57 PM
Jeff92se's Avatar
Red Card Crew
Well 04.5 might as well be 05. You know how that goes. I take it you have the newer tranny logic as stated though. If not, then THAT would be something odd.
Old May 18, 2007 | 09:49 PM
OCG35's Avatar
there were a few changes in mid 04 but not as many as the 05... People always wonder why 04.5 owners say thats the year they have... well this is why. Becasue it's a little dif than 04 - definitley not an 05 though.
I don't know what "tranny logic" is... so I'm not sure I have that.
Old May 21, 2007 | 02:00 PM
Jeff92se's Avatar
Red Card Crew
In MM mode, does the tranny automatically go into 1st gear? Does the tranny rev match on downshifts?
Old May 21, 2007 | 11:21 PM
OCG35's Avatar
it only goes into 1st gear automatically when below 800rmp or so... no rev match.
Tukeeg35
Engine - Electrical
Aug 19, 2015 02:08 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Ninjay16
Jul 20, 2015 01:21 AM
Cskeet
Jul 19, 2015 12:38 AM
