Help! My fuel door won't unlock..
Old Oct 11, 2007 | 08:14 AM
  #31
Nappy's Avatar
Originally Posted by PotomacG
Thanks. I actually ran a thin wire to the release pin so I could manually pull it from inside the trunk until I find a replacement.
UPDATE:
I found a replacement Fuel Door Actuator
Part #78850AL500 for $67. It will take 5 minutes to replace.
The stem on my plunger broke. Is this the part I would need to fix it? And can it be found online? I checked infiniti-parts.com and they don't seem to have it.
Old Oct 11, 2007 | 08:30 AM
  #32
blownvert's Avatar
how come my 04 g35x does not have locking fuel door?
Old Oct 11, 2007 | 12:41 PM
  #33
MidnightG35X's Avatar
It should... mine does
Old Oct 11, 2007 | 01:01 PM
  #34
HillyHead's Avatar
This happened to me one time. I took my g/f's '03 G Coupe out and it needed gas the light was on.
I pulled into the gas station and start pressing the fuel door it's not popping open. Now I'm in a semi-panic feeling like a complete idiot cause I can't get the fuel door open. I call the g/f.
We both work at Carmax. She had this happen to her on a G sedan. For 15 minutes she and a few other people couldn't figure out how to get it to open, and then somebody decided to hit the unlock button and it popped open. I completely forgot about it and she suggested it and it popped open.
Still not quite sure why the car has that feature.
Old Oct 11, 2007 | 08:23 PM
  #35
blownvert's Avatar
really? where is the gas opener button? I can just pull open my door, its not locked.
Old Oct 12, 2007 | 10:29 AM
  #36
The only gas opener button is the unlock button. Whenever the driver's side door is unlocked with the key fob or the power door lock switch the gas tank cover should unlock. If it neither locks or unlocks, you have the opposite problem as this thread's title... yours stays unlocked. Either way, the solution is most likely the same. You can find the little plunger thing if you open the trunk, undo a couple clips on the passengers side trunk lining and pulling it down. You should see a little white plunger thing and that's the lock.
Old Oct 12, 2007 | 03:23 PM
  #37
PotomacG's Avatar
Originally Posted by Eticketride
.... PotomacG, let us know how the installation went.
Sorry. I haven't been here in a while. The replacement did take about 5 minutes. There is a black retaining ring inside the fuel door compartment. Twist this ring and it comes off. After you pull the padding away from inside the trunk, unplug the electrical connetor from the actuater and then it pulls right out.
Push the new actuator through the hole, twist the rataining ring back on and plug the electrical connector back on and that's it.
Not worth a drive to the dealer unless it's a warranty repair.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
G35-R
Nov 7, 2015 01:21 PM
douglas555
Sep 10, 2015 04:48 PM
Rhinos7777
Sep 6, 2015 05:36 PM
jbmw002
Sep 3, 2015 08:42 PM
